Death wobble after new wheels on stock jk Help
Old Apr 21, 2013 | 06:51 AM
filthy-Beast's Avatar
On a side note. I'm always amused at the talk of steering stabilizer to stop DW. First time I got DW, it completely destroyed a brand new OME stabilizer.
Old Apr 22, 2013 | 06:20 AM
planman's Avatar
Forum Tech Advisor
Originally Posted by jmblount28
I got a set of pro comp rock crawler 97 with 4.25 bs. I had them installed on my stock jku Rubicon (waiting on lift to come in) and they used the factory lug nuts. On the way home I got my first experience with death wobble. I had the tires rebalanced and everything checked from the death wobble fix thread and nothing. Called pro comp they said it is the lug nuts that factory ones will not work and will cause the death wobble. Is this correct? I have been searching and saw plenty of people using factory lugs. Thanks in advance
The factory lugnuts are fine.
Many people make the mistake of failing to remove the stock lug retainer clips when they either run wheel spacers or aftermarket wheels. This can cause a bad shimmy. The shimmy could help trigger full out, rip your front end apart death wobble, but it isn't the primary source of the problem(s).
Maybe you failed to remove the clips and it exposed other weaknesses in your system.
The lug retainer clips are flimsy and not on every stud. They are used in the assembly line process to hold the disc brakes on. They serve no purpose after initial assembly. Stock wheels have notched out spaces around the clips that still allow the wheel to sit flush on the disc.
These retainer clips absolutely must be removed in order for an aftermarket wheel or wheel spacer to sit flush on the disc/mounting surface.
Old Apr 24, 2013 | 01:51 AM
Kojack's Avatar
Originally Posted by filthy-Beast
Correct you could only see them move with the leverage of the 2x4. No I had no clunk. Heavy vibs as I approached 50 mph and would go into full DW if I hit a bump or swerved. Weird part was if I got up to 70 mph it was smooth as glass and would not go into DW, the laws of centrifugal force I guess.
OK. I have to get them to look again. Also, I also get a low freq. Scrape/squeak noise from the drivers side front suspension over a rolling bump on the road. I still think my joints are toast, plus my steering shaft need grease.
Old May 2, 2013 | 05:32 PM
jmblount28's Avatar
Just wanted to update I went and got a new set of duratracks and so far so good. I don't know if the old tires were triggering it or what. I do still have a slight shimmy starting at about 45 still but I can deal until I find out the cause. I am having a lift installed and told them to check everything over really good hopefully they will find it.
Old Oct 29, 2018 | 07:51 AM
Dan Maldonado's Avatar
Default Wow!
I’m shocked that this was the cause of the wobble! After reading this yesterday I pulled both front tires, removed these clips and set off on a drive. No wobble, no shimmy, nothing....I’ll be damned. Can’t believe these little clips were causing such disruption.
Old Oct 29, 2018 | 08:34 AM
resharp001's Avatar
Loved
Community Favorite
Those clips are not the cause of DW, and Planman even says as much in that post. Several things can assist in "triggering" a wobble, but a wobble is the results of loose bolts and bad joints. Regardless, those clips should be removed. I can see how if an aftermarket wheel/spacer is not sitting flush, it could throw off a balance, and THAT could start to trigger issues, but rest assured, if it does, it's because there is an underlying problem.
Old Oct 29, 2018 | 08:44 AM
jedg's Avatar
Vet Army
I'm with resharp on this one. Those clips will cause shimmy. They might trigger DW, but the DW will be from components involved in the steering geometry.
