The DEATH WOBBLE database
Old Jul 22, 2009 | 07:41 AM
  #71
Octogoogles's Avatar
Year and Model
2007 X 2dr Auto
2. Current Mileage
20.000
3. Approx mileage when DW started
17.000 (When lift was installed)
4. Suspension (OEM, etc. Make sure you list all components like AM trac bar, CAs)
OME Long Travel shocks, OME HD springs, Currie front lower CA's, JKS front and rear trackbars, JKS Discos up front and Currie in the back.
4. Wheel/Tires/spacers
18" Gatlins with 35x12.5 BFG KM2's
5. What measures you have taken to resolve DW
I retourqued all the bolts including the Jam nuts on the trackbars which were loose!
6. What was the"fix" or are you still dealing with it
Retourquing everything fixed it. Have had no issues the last 3000 miles including long trips going as fast as 85mph
Old Aug 11, 2009 | 05:30 PM
  #72
jmontgomery123's Avatar
Default Solved my DW
1. Year and Model
2007 rubicon Unlimited
2. Current Mileage
65,000
about 4 months after lift
Rancho 4" sport (basically Rancho springs and shocks, relocated stock everything else)
5. Wheel/Tires/spacers
stock wheels, 35's, spider track spacers.
6. What measures you have taken to resolve DW
see #7
7. What was the"fix" or are you still dealing with it
it happened more and more frequently, so i assumed when it got bad enuff, i'd find it.... and i did. The trackbar relocation brackets were very loose letting the front end move... welded bracket in place and NO MORE DEATH!!
this also stopped my skid correction from engaging everytime i rounded a corner...
Old Aug 12, 2009 | 03:44 PM
  #73
alaskabound's Avatar
[QUOTE=wayoflife;1247053]but, if you look under a stock jk, the draglink and track bars ARE parllel to each other and virtually parallel to the axle. in fact, they are more so than just about every lift kit out there that comes with relocation brackets, flip kits or dropped pitman arms. the only 2 kits that i know of that match factory settings are rancho and aev.
Can anyone say that there is a less chance of having problems if you choose the rancho or aev kit?
Old Aug 12, 2009 | 03:48 PM
  #74
xpberb's Avatar
Originally Posted by BEACHN JK
Year and Model
2008 X 4dr Auto
2. Current Mileage
16.000
14.000 (When lift was installed)
4in Rancho LA kit with fox shox
20x9 Moto Metal with Toyo M/T 37/13.50/20 1 1/4 spacers
I retourqued all the bolts on the lift and have tires balanced
Still dealing with it
Any ideas?
__________________
what had to be done to mine:
1. replace camber and caster joints
2. 2 way alignment
3. new bolt heads for track bar, sway bar, etc
Old Aug 12, 2009 | 04:28 PM
  #75
greenamphibious's Avatar
NO!.........
Old Aug 12, 2009 | 08:43 PM
  #76
bOLsAK=3's Avatar
i guess that's what i still don't understand. the factory geometery is designed well. in fact, companies like aev have designed their kit to restore the steering geometery to being that of factory. likewise, i personally have driven and know plenty of people with jk's that are lifted and DO NOT have correct steering geometery and NONE have death wobble.
the single biggest factor i have seen as being the cause of DW has been loose track bar bolts (no uncommon after doing a lot of wheeling with extreme articulation). and, if there is a complaint that i have about the factory setup, it's that the factory mounts are very weak - especially the track bar mount at the axle. i have personally seen several of these break and have seen/heard of even more here on the forum. this is especially a problem with people running track bar relocation brackets mounted to the axle and without additional support but i have seen unaltered track bar mounts fail too. and, for the record, i have personally broken a track bar mount at the frame and know that toad has as well. all of these things have lead to DW and once fixed, eliminated DW.
You broke a track bar mount at the frame??? Damn... Which ones broke? The fact that my track bar broke off of my front axle has me checking my axle often. Now you say that they brake at the frame too?! Crud...
Old Aug 13, 2009 | 06:04 AM
  #77
Originally Posted by greenamphibious
NO!.........
you don't need to yell.
If these two companies are going to the trouble to maintain factory geometry just seems there would be a benefit to it.
Old Aug 13, 2009 | 07:18 AM
  #78
Every company has an "angle" no pun intended....
Old Aug 13, 2009 | 07:28 AM
  #79
BotsJeep's Avatar
Year and Model
2007 X 2dr Auto
2. Current Mileage
Just over 30K
29K
OME HD Kit 3.5"
JKS Adj Track Bar F & R
17X9 ZD Series Addict w/ 35x12.50 KM2s
Balance & Wheel Alignment
My Tie Rod is shot..so will have that replaced too..but the DW has gone
Old Aug 17, 2009 | 12:48 AM
  #80
Freek's Avatar
1. Year and Model
Unlimited X stock
2. Current Mileage
37500
37000
All Stock
Stock, 16"
Not yet, dealership next Wednesday
replaced steering stabilizer,turned out to be broken and,according to an official Chrysler service memo mounted the wrong way on all models produced before April 07 , dealer installed a new one ,the right way
