Delayed throttle response
Old Sep 8, 2010 | 06:24 PM
  #31
Jeepaolic's Avatar
i have a 2009 6 speed sahara and when reading your post, it was like driving my jeep. I have noticed it since I got my jeep and was sure it was about trottle lag as describe in this forum but it looks like 2 different things. And for me, it is not happening all the time, but most 80% of the time .when shiftin a 2200rpm, then the jeep almost stall,then pick up. the only solution is to shift around 3000-3500rpm, but mpg suffer lol. I have not took the jeep to the dealer because I think most people will think it is normal.So the dealer.
keep the good work, looks like you're into something with the advance timing thing.....
Old Sep 8, 2010 | 06:53 PM
  #32
xact's Avatar
Originally Posted by tslewisz
One of the early questions in this thread was about years affected. My '10 doesn't do this stuff.
I agree.. no throttle oddities with my 2010 either. Superchips' throttle response adjustments aren't even available for 2010's - so something definitely changed.
Old Sep 9, 2010 | 05:28 AM
  #33
Doc_D's Avatar
Originally Posted by Locklain
Sorry to revive an old thread but have you heard anything back Doc_D? Mine has been doing this same thing forever and, of course, the tech guys play dumb when I bring it in.
Superchips had one of their engineers look into it. Their response was that it's not torque management. Well at least not with their tune. With their tune they said total timing should never go negative due to torque management. They believe it's Chrysler's throttle rate retard algorithm that was causing the issue. Basically fast movements of the accelerator, such as tipping into the throttle after a shift, cause a massive reduction in timing. That's the hesitation we're feeling. They basically said there is nothing they can do about it.
Old Sep 9, 2010 | 05:41 AM
  #34
Grant_T's Avatar
Yeah, I get that "lag" quite often (6 speed)...most often just after shifting into 2nd gear....in fact, I think that is the only time I have ever felt it.
I am running a Superchips as well.
Grant
Old Sep 9, 2010 | 05:56 AM
  #35
JPop's Avatar
Grant
Interesting as I do a lot of first to third shifts winding out first gear so I am hitting third at about 1500 rpm.
Old Sep 9, 2010 | 06:00 AM
  #36
viking's Avatar
I have had my sprint booster in for about 2 months now and it is the real deal. I have the superchips too and did nothing about the delay by the drive by wire. The sprint booster takes the lag right out of it. May not look like much but you will be happy . I would have liked to see what this did before all the other mods I did to help the throttle response. So I say go for it.
Old Sep 9, 2010 | 06:20 AM
  #37
Doc_D's Avatar
The hesitation we are talking about here is the result of a major reduction of total engine timing under certain circumstances. It is not related to lag between changes in the accelerator pedal and movement of the throttle plate.
I'm not sure how the sprint booster could affect an internal PCM algorithm that drastically reduces total ignitional timing based on the rate of change in accelerator pedal position.
Old Sep 9, 2010 | 07:47 AM
  #38
PG-JKU's Avatar
This happens in my 2007 6 speed. The first time it happened i thought I was going to stall, 1st to 2nd shift going around the corner. Used to be able to go around corners and gun it in 2nd with both my 4.0L XJ and YJ - now it just feels like it wants to wait a while before it goes. My son drives a 1992 XJ and he says that the JK feels much wimpier at the low end too.
Old Sep 9, 2010 | 07:50 AM
  #39
07rubigreen's Avatar
My lag gear in my 2007 manual seems to be 4th. Whenever I shift from 3rd to 4th at about 2000 RPM's I get a pause before the engine wakes up and starts moving me forward again. Extremely annoying and I've had to wait until around 2,500 RPM to shift from 3rd to 4th to combat it.
Old Sep 9, 2010 | 07:58 AM
  #40
viking's Avatar
Well I have had my JK 6 speed since 07 and 125000 on it and have not had a delay at different shift points like some of you's have. The only throttle response problem was when I step on the gas at any point in shifting there was a lag, and this takes it out.
