Diesel conversion seriously being considered
Old May 20, 2012 | 04:44 PM
  #31
highwayman's Avatar
Nice conversion, looking forward to updates.
Old May 21, 2012 | 02:48 AM
  #32
lopezv123's Avatar
Originally Posted by h20squirter
That's the motor that's gets put into the export CRD JK's so I'm guessing it will work pretty good. I know that of they don't come out with a CRD JK in the next couple years that is the motor I will be swapping into mine.
I think the CRD is a bit more civilized than the 4bt but not sure if it's as reliable and it's definitely lower torque. Seen some info on this forum and on line that suggested the 4bt can run for over 200k miles and can also be easily converted to run on other fuels like bio diesel or waste oil so this is the route i'd rather go. Problem for me is cost of the conversion is way too high. Other issues (which are not major IMO) are that the 4bt apparently smokes quite a bit if not perfectly tuned and they are loud.
I think there are also some places doing VW diesel conversions on jeeps but not sure if the JK is a candidate for this or just the older models.
Old May 21, 2012 | 03:27 AM
  #33
ReconJeep's Avatar
The diesel JK engine is made by VM in Italy and is very unreliable. Definitely go with the Cummins. Very reliable and torquey. Many more options available for it with much less electronics. You are also not stuck having to go to Jeep for parts.
"Ex Umbris Venimus"
Sent from my iPhone
Old Oct 23, 2012 | 05:21 PM
  #34
ridelots24's Avatar
subscribed.
Old Oct 23, 2012 | 06:45 PM
  #35
a4x4high's Avatar
You just cant go wrong with a cummins as for vw diesels depending on the year they are a dirty running deisel , the guy that did my etest on my ram says he fails alot of vw diesels. Plus once you get the drive train toughened up you should be able to oost those hp and trq numbers quite a bit.
Old Oct 23, 2012 | 07:00 PM
  #36
un-ltd_sahara's Avatar
here is project Rattle Trap
Project Rattle Trap Meets Moab - 2012 - YouTube
Old Oct 23, 2012 | 10:44 PM
  #37
courtsm3's Avatar
i will wait and see if jeeps come with a diesel option in the coming years. with new emissions starting for 2016, i can see jeeps coming out with a HE Diesel.
but all the best with the build!
Old Oct 24, 2012 | 04:20 AM
  #38
doc5339's Avatar
Veteran: Navy
Originally Posted by arjeeper
If it were me, I'm not sure I'd put that much cash to get the VW engine based on it's numbers. Now, the 4BT numbers looks awesome! This could be really cool!
It is a "VM Motori" 2.8 liter Inline 4 cylinder Turbo Diesel previously used in U.S. Jeep Liberty CRDs, and currently used in Foreign Jeep Wrangler Diesels; unless I am mistaken.
It is NOT a "VW" 1.9 liter or 2.0 liter Inline 4 cylinder Turbo Diesel used to power Golf, Jetta, and Passat TDIs.
Old Oct 24, 2012 | 06:36 AM
  #39
dognights's Avatar
Just a question. Did you look at just importing a foreign JK diesel that was from the factory? I mean I cant see it costing $20k plus to sort out import details for something like that. Plus then you would have a full factory warranty with it for a couple of years as well. It just seems like a ton of clams to spend on something like that.
Old Oct 24, 2012 | 06:55 AM
  #40
dellpjJK's Avatar
please keep us up to date on this. I'm also seriously considering this in the next year or so...
