Diff Fluid Fill Amounts
Old Dec 17, 2008 | 07:10 PM
JackMac4's Avatar
Originally Posted by chuck45
Is that exactly true. I was told that some oil had to be flung forward to lube the bearing where the pinion enters. But I don't know if this is true or not.
The question as to how much comes up with the ARB covers that I have because the fill hole is high and it has a dipstick. I like them becaause of the dipstick since after running in water I can pull the dipstick and chck for "milk". The shop that put the gears in put the covers on and they put a notch in the dipstick at the level of the factory fill hole.
Does it hurt to run a little extra, go a little higher on the dipstick. I've also been thinking of changing to Royal Purple. My understanding is that no additive is needed for Rubi's; only for JK's equipped with the Trac-Loc limited slip.
I just looked in the manual; it doesn't even give the amounts needed for the axles, transfer case or auto transmission. Does anybody know those amounts?
There are write-ups with all the necessary amounts on project-jk. It doesn't hurt to run extra, you just risk having it come out your breathers and making a mess. A lot of people run theirs filled high. I personally use Mobile1 - a good synthetic thats middle of the road - better than stock, not as expensive as RP. You are correct about the additive, only LSD's need it.
Old Dec 17, 2008 | 09:38 PM
odin725's Avatar
Originally Posted by jerseyjk08
What kinda fluid did you guys use? I went to Pep boys today and paid $70 for 4 quarts.. that seemed kinda expensive. it was Royal Purple SAE 75w-90. I was just wondering if that was too much to spend. I really don't care if its not the best stuff since I plan on changing out my gears hopefully before spring anyway.
I use Schaeffers Synthetic gear lube. i have been really impressed with it,but i do have to order it online but it is under 10 bucks a quart
Old Dec 18, 2008 | 03:05 AM
afoulk's Avatar
Where did you find the Schaeffers stuff online? I've looked and didn't find anything, and the closest dealer to me is atleast an hour away. I've always been a big fan of their stuff.
Old Dec 18, 2008 | 03:06 AM
afoulk's Avatar
Oh, and just incase some don't know, most synthetic gear oils you can get today, have the limited slip additive in it already. It should say some where on the bottle.
Old Dec 18, 2008 | 03:12 AM
odin725's Avatar
i got it from ...speedpartz.com
they have it for $11.25 a quart.I thought i paid just under 10 bucks a quart for it but i must of been mistaken
Old Dec 18, 2008 | 04:54 AM
RedneckJeep's Avatar
Most gear oil is in the 90 weight range. when you couple that with a 360 degree ring gear with teeth on it that actually PICK UP the gear oil, you can see that it's gonna go every frikkin where in that case, includin all over the pinion. Even if the pinion is pointing nose down, so the gear oil will run out of it at rest, while the Jeep is in motion, it and it's bearings are gettin drenched.
...and as for the discussion on the fill level. This oughtta be kinda simple. If you have the stock covers. Just go by what the owner's manual says. I've found sometimes you have to disregard the fill hole. You may have to jack one side of the axle up to get the required amount in. Now, if you have aftermarket covers, they SHOULD come with some kinda deestruckshuns tellin you how much or how to fill. Since they probably have a different interior profile than stock, that may change the amount the axle holds. Truthfully, if about the boottom third of the ring gear is submerged, that's about all you need. Since the axle housing ain't made outta that clear cast iron yet, that's kinda hard to tell though.
Old Dec 18, 2008 | 06:10 AM
ronjenx's Avatar
On the rear axle, the outer axle shaft bearings are lubicated with oil from the differential housing. Whatever amount of oil you decide to have, it must be higher than the bottom of the axle tubes. This will ensure adequate oil to the outer bearings. The front axle may be the same, except it would be to keep the shaft seals wet.
Old Dec 18, 2008 | 06:49 AM
bobzinger's Avatar
I just installed Riddlers last weekend. Just like the posting on project-jk write-up comments, my front 30 took just shy of 1.5 bottles (came to the fill-hole) and the rear 44 took just shy of 2.5 bottles (just a smidgeon under the fill-hole). I'm running Valvoline 75W-90 Synthetic that I picked up from Napa. It was about $11/bottle. I checked PepBoys for Royal Purple but they were out. So far, so good.
Old Dec 20, 2008 | 07:15 AM
smalls's Avatar
I love beating dead horses....
SO... for my jeep
front 44 - 2 quarts
rear 44 - 2.5 quarts
Correct?????
Old Dec 20, 2008 | 01:15 PM
chuck45's Avatar
So the project JK write-up says:
Front Differential Capacity:
2.7 pints (1.35 quarts)
Rear Differential Capacity:
4.75 pints (2.375 quarts)
Is this assuming the front is a D30? Are these amounts applicable to the front D44? Does the rear hold that much more fluid? I have ARB cover and no longer have my originals so an exact amount on the front would be good to know. Strangely the owners manual gives no amount.
