Disabling TPMS? It is possible?
Old Mar 6, 2009 | 05:56 AM
  #51
greenamphibious's Avatar
you CAN mount them in the spare. the OLD style tpms required motion... newer systems do NOT
it is ILLEGAL but who cares
and I traded in a vehicle no problem with sensors removed. It isn't ILLEGAL to remove sensors, it is ILLEGAL to render the system usleless
Old Mar 6, 2009 | 07:32 AM
  #52
Jeff09's Avatar
It would be hard to forget about the changes made, and what may happen down the road.
Maybe it would never be an issue. In the event there was ever a problem, I would sure expect to be contacted by someone when they realized the TPMS sensors had been relocated.
Maybe it's just me; but, I wouldn't want that hanging over my head.
Old Dec 2, 2009 | 04:38 PM
  #53
metro7100's Avatar
I put my 35's on and had them flash mine to 30 psi. They just took a small tool and changed it, took them a few seconds. I had one flash off again, when I took it back they reflashed them again and I have never had a problem since.
I do know if you use nitrogen instead of air when it is cold the lights will come on. Took the truck down and had them lower it even more. Havent had a problem since.
Old Dec 2, 2009 | 04:45 PM
  #54
nthinuf's Avatar
Originally Posted by NebRedrocker
I know this is bringing up an old topic but the light is driving me crazy. I put my 33's on and now the light is on. I had the dealer set the parameters and am now wondering what those parameters are. I run them at 32 psi could they have them set at 36 or something like that? Also does the Pro Cal have the option to set the tpms parameters?
The docs are on their website...
Tire Pressure Monitoring System (TPMS) Mode Description: This mode allows the user to modify the factory Tire Pressure Monitoring System (TPMS) low tire pressure threshold values. In stock configuration, when tire pressure drops below the factory threshold value, the TPMS warns the driver by illuminating a dash warning lamp. The ProCal Module can establish alternate threshold values so that low tire pressures can be utilized without triggering a warning. Generally, the warning threshold is set 4psi less than the desired tire pressure (ie. set the threshold at 24 psi for tires running at 28psi). For a detailed description of TPMS functions please consult your vehicle’s Owners Manual. Notes: Disabling the factory TPMS should be used for off road use only and may not be legal to change is certain countries, please check local regulations. For on road use, please consult your tire manufacturer to determine an appropriate value for your vehicle’s tires and gross vehicle weight (GVW). Some users have reported the TPMS indicator lamp staying on after setting the Low Pressure Threshold to a new value. The TPMS sensors use timed and pressure-loss triggers to update the vehicle of tire pressures. In the event that the Low Pressure Threshold has changed to a value equal to or higher than actual tire pressure, the tires must be inflated to at least 5 psi over the new low value. The vehicle must then be driven up to 10 minutes above 15mph before the TPMS sensors update the vehicle of the new tire pressure. Once the reported tire pressure is 5psi above the Low Pressure Threshold the TPMS indicator lamp will turn off. Procedure: Consult the Quick Reference Guide and set the DIP switches accordingly. With the engine off and ignition on, plug the module into the OBD port and wait for the horn to sound. If the horn does not sound, consult the troubleshooting section of these instructions.
Old Dec 2, 2009 | 05:10 PM
  #55
AZ Red Rock Rubi's Avatar
Superchips Flashpaq allows you to re-program TPMS and they even throw in improved performance settings!!
Old Dec 4, 2009 | 06:05 AM
  #56
OzzieBrutus's Avatar
Thanks for all the information. So I'm pretty much guessing by now, that there is no way to disable these sensors? Would that be correct? I live in Australia, there is no law that commands the use of these TPMS's as part of the roadworthiness of the vehicle. I'm yet to consult a dealer about this, but rather hoped there would be something a little more defintive on here! Shame. Good luck.
Old Dec 4, 2009 | 06:17 AM
  #57
awndray's Avatar
I don't know if this has been mentioned, since I haven't read all six pages, but try this. Go to the dealership, ask them to plug in the computer and to set the minimum pressure to 0.
Old Dec 4, 2009 | 07:02 AM
  #58
Locklain's Avatar
A dealership wont disable the TPMS. Since the TPMS is required by a federal mandate a dealership could land in hot water for disabling it.
Old Dec 4, 2009 | 08:08 AM
  #59
awndray's Avatar
You're technically not disabling it. You're just setting a lower pressure
That being said, really? A federal mandate, for tire pressure monitoring? Weird. Wonder if that's the case for Canada. I'll look into it ...
Old Dec 4, 2009 | 08:12 AM
  #60
Canada's Avatar
True... Unfortunately.
