DIY control arm
I am an avid DIYer too and was hoping to save a bunch on a lift by buying one that lacks some of the major components like control arms so that I lock, regear, and lift at the same time. I'm also a pretty good welder (I'm a high school shop teacher and teach welding, so I don't have any certifications but I am pretty good). For another project I just bought 20ft of 2" OD .25" walled piping for $235 which is actually what gave me the idea to start with. I do still need to price out the joints.
Thanks for all the input, I going to continue researching and debating with myself.
Your 2" is good for the lower arms but I would use some 1.5" or 1.75" for the uppers and look into double adjusters for the uppers. Synergy sells the double adjuster and it just makes life much easier when adjusting if you are always messing with the jeep. If not then save the money.
Who breaks control arms, really? I have never seen a broken control arm, ever. Some bent long arms but never broke. I broke a metal cloak joint once off an arm but that was before they came out with their forged joint.
If I may? Could we back up some? Why are you replacing all 8 control arms? Most don't typically do that unless you start going over 4inches of lift and rolling with 37 or larger tires.
Just trying to figure out another path to eliminate the $1200 delima you're looking at.
ON a short arm all you have to do is pull a factory arm and match the angle and set the threaded end so you are at factory length when the end is screwed all the way in. Lots of end joints out there but yes it is important to choose the right ones for you as this is the bulk of the expense. I have a thread on a comparison or control arm joints on Jkfreaks.com Control Arm End Joints Comparison and review
You only need to mess with geometry calculators when you're relocating or changing the positioning of the brackets on the axles and/or frame.
Make your own arms, it's fun.
