Do I Need Rear Control Arms?
Old Oct 15, 2011 | 06:50 AM
CHIPPER916's Avatar
Default Do I Need Rear Control Arms?
I know that at some point in the past I have seen this topic discussed, but I cannot find it.
I have a 3.25" lift and a couple of weeks ago I went to a tire that is slightly larger. I can see that the new tires will make contact with my Rubicon rock rails when flexing. I still have the stock control arms which has worked fine up until now. Would rear control arms be what I need to relocate the rear axle to stock position, or should I just trim the rock rails and pinch seam to prevent the tire from rubbing them?
Old Oct 15, 2011 | 09:25 AM
nthinuf's Avatar
Trimming the pinch seam and rubi rails is free. You would need both upper and lower arms to move the axle back, which really isn't needed with a 4door. So trimming gets my vote.
If/when you swap out the rear driveshaft for a double cardan you will want upper arms, though.
Old Oct 15, 2011 | 05:03 PM
Battlefrog's Avatar
X2... I trimmed my rails and pinch seam and I've got no rubbing in the rear while flexing...
Old Oct 15, 2011 | 05:58 PM
T&ERun's Avatar
I have rear uppers and lowers and have them dialed in to Teraflex's specs and I have no rubbing on the pinch seam with my 3" and 35s.
Old Oct 15, 2011 | 06:09 PM
jeep2007's Avatar
I used Planmans recommendations and my 37s at full stuff have no rub at all.
Old Oct 15, 2011 | 06:16 PM
Bxjk's Avatar
Where would I find teraflexs specs ? Are they on their webpage?
