Do not install Detroit Soft Locker on 2012+ Jeep JK with automatic
#51
Sponsoring Manufacturer
#52
Since you guys seem to know what you're talking about, can someone tell me if I can add an E Locker to my OEM rear Trac Lock limited slip or does the E Locker totally replace it? I want the LSD for daily driving more than I want the ability to fully lock the rear up. But I was on the Jeep site last night and the new Moab version comes with the LSD but has an optional full locker and the way I read it made it sound like you'd have both if you opted for the optional locker. Ideally, I'd have both. But if not, my plan is to keep the OEM Trac Lock in the rear and add the E Locker to the front. Thanks.
#53
However the lsd is for offroad use not the street. The traction control system is far more responsive on the street than an lsd.
#55
JKBender: on wet pavement, I would think the LSD would transfer power to the second tire upon slipping, and then both tires would need to spin to get the TC to kick in. Do you think that's correct? That's what seems to be the case on my JK. The pavement pulling out of my office is slick when wet. It seems like if I just throttle it enough, and feather it, I can get the back end loose and keep the tires just barely slipping before the TC kicks in. Thoughts anyone? I heard the ECTED wears out even faster than the Trac Lock will. Thanks guys.
#56
I would suspect that the lsd would delay the response of the tc system. I petsonally like an air locker because it gives me a locked diff on the ttail and on the street I am not influencing the tc system at all. Also, the jk's new break lock diff system (bdl) is about as good as a ls in my opinion, so I belive the air locker alows for the best of all worlds.
My issue that this thread highlights is that my 12 auto cannot be run locked in high range. This is an issue for me at the sand dunnes.
#57
There are no adjustments to make on the rear axle....even if you have adjustable rear control arms the only thing your are going to do is adjust pinion angle....but they still does nothing as far as alignment goes.
If the shop claims they did a 4 wheeln alignment then you got taken.
Now they put those alignment paddle things on all for wheels regardless of the alignment performed.
#58
Abs light.
I have a 2009 2door manual trans. Just had a Yukon locker installed in my dana30 and all the abs esp and traction lights come on then go off when it feels like. I guess the locker is freaking out the computer. Thought it was my sensors but replaced all and still goes on and off steering is centered and everything probably just the computer freaking out with the Yukon locker. Anyone else in counter this type of situation?
#59
I am looking to regear my 2012 auto from 3.21's to 4.56's and put an ARB in the rear. Am I looking at problem's with the ARB? Should I just go open front and rear? I eventually wanted to put a PR44 in the front as well but that's at least 2 years. Anyone put an ARB in a 2012 Auto?
#60
