Door stuck?
Old May 22, 2014 | 04:45 PM
BLACKJacK's Avatar
Default Door stuck?
This is really strange problem. I remove this screws at the bottom of the doors all the doors came off but the passenger rear door will not come out of the hinges. Any ideas?
Old May 22, 2014 | 05:08 PM
afpilot82's Avatar
JK-Forum Ambassador
You can use a jack and a block of wood and slowly jack it up until it pops free. Add some grease to the hinge pins next time you put the doors back on.
Old May 22, 2014 | 05:34 PM
BLACKJacK's Avatar
It was the first time I have had the doors off since five and the vehicle. Turns out that my neighbor who owns a TJ came over and showed me where the hinge was pinching for some reason or another.
I was trying to take the door off with it all the way open however he lifted it where it was closer to being closed.
Thank you for the input. I will add some grease to it when I put them back on after this weekend.
Old May 23, 2014 | 03:30 AM
CombatDiver's Avatar
I had the same problem the first time I took all my doors off. At least for me some break free worked. When I out them back on I lubed them really well which may or may not help (I haven't taken them off for nearly two years now so I don't know if I'll have a problem when I do).
Old May 23, 2014 | 03:38 AM
SpicedCrusher's Avatar
Had same issue last year trying to get my doors off, except it was all of them. Used the jack method and once off changed out all the door liners with TMR Customs Derlin inserts. Come off so easy now, definitely worth it.
