Dose 33" and 1.5 TERAFLEX Leveling Kit will work!?
So, got tired been stock and I'm trying to do my homework...
Don't like my Jeep on 35 or higher... to much for me to handle
(my friend have one on 35, so I know, I tried.)
Any one have pics of there rig with "TERAFLEX JK 1.5" Performance Leveling Kit" and 33"?
and maybe some steel bumpers...
or perhaps 1.5 lift is to little for 33" with steel bumpers...
Please don't suggest BB or spacers, I want my lift to functional... (coil)
Please help! and THANK you all!
Any one have any pics of the "1.5 TERAFLEX Leveling Kit" installed
the 32" is not that bad, all I need is a little bit of a lift to clear the steel bumpers...
Here's mine with the Teraflex leveling kit. The front sagged back down a bit from the weight of the bumper and winch, I ended up with about 1" of lift front and back with this setup.
First pic is with the stock Rubi 32"s, second is 33" Duratracs.
I did have to add a few extra components besides the coil springs with this lift:
Longer shocks
longer rear swaybar links
adj front and rear track bars ( help center the axles)
Adj front lower control arms ( bring the caster to better than stock +4.2).
2" bumpstops
Overall, I am very pleased, I went the 2" BB spacer kit and it worked but I should have went right to the coil spring lift as the stock springs will sag bad from the extra weight of bumpers and winch. Also, if you ever decide you can easily fit 35's if you decide to change your mind on getting bigger tires down the road.
I have the original spacer version.
