Dose 33" and 1.5 TERAFLEX Leveling Kit will work!?
Old 11-22-2010, 10:09 AM
Classified.Spirit's Avatar
Default Dose 33" and 1.5 TERAFLEX Leveling Kit will work!?
So, got tired been stock and I'm trying to do my homework...
Don't like my Jeep on 35 or higher... to much for me to handle
(my friend have one on 35, so I know, I tried.)
Any one have pics of there rig with "TERAFLEX JK 1.5" Performance Leveling Kit" and 33"?
and maybe some steel bumpers...
or perhaps 1.5 lift is to little for 33" with steel bumpers...
Please don't suggest BB or spacers, I want my lift to functional... (coil)
Please help! and THANK you all!
Old 11-22-2010, 10:13 AM
Coondog33's Avatar
Yes I do...
ID:	104150Click image for larger version
ID:	104151Click image for larger version
Old 11-22-2010, 11:11 AM
RevyJKU08's Avatar
33's with OME HD coils spring lift...+3" of lift but no sagging with the additional weight of bumpers and winch! Off-road and on-road manners are great!
Old 11-22-2010, 12:07 PM
WOW, Now that look nice!
So, 33 with 3" coil lift ea? interesting...
Do you have more pics please? side profile...
Old 11-22-2010, 12:58 PM
Any one have any pics of the "1.5 TERAFLEX Leveling Kit" installed
the 32" is not that bad, all I need is a little bit of a lift to clear the steel bumpers...
Old 11-22-2010, 01:01 PM
dmhines's Avatar
I thought TF only had one leveling kit for the JK ...
Lift it 1" in the back and 2" in the front ....
Old 11-22-2010, 01:20 PM
jbro's Avatar
Here's mine with the Teraflex leveling kit. The front sagged back down a bit from the weight of the bumper and winch, I ended up with about 1" of lift front and back with this setup.
First pic is with the stock Rubi 32"s, second is 33" Duratracs.
Old 11-22-2010, 02:49 PM
RevyJKU08's Avatar
It is actually a 2" HD coil lift which ended up netting me over 3" of lift. I went with this kit with the addition of bumpers and winch....BUT...
I did have to add a few extra components besides the coil springs with this lift:
Longer shocks
longer rear swaybar links
adj front and rear track bars ( help center the axles)
Adj front lower control arms ( bring the caster to better than stock +4.2).
2" bumpstops
Overall, I am very pleased, I went the 2" BB spacer kit and it worked but I should have went right to the coil spring lift as the stock springs will sag bad from the extra weight of bumpers and winch. Also, if you ever decide you can easily fit 35's if you decide to change your mind on getting bigger tires down the road.
Old 11-22-2010, 03:07 PM
dstock's Avatar
Here's another TF leveling kit and 33" Duratrac:
Old 11-22-2010, 03:45 PM
cbeas's Avatar
They have 2 now. You can get the coil spring spacer that sit on top of your factory springs or you can get replacement coils that lift it about the same 2" in front & 1" in back.
I have the original spacer version.
Quick Reply: Dose 33" and 1.5 TERAFLEX Leveling Kit will work!?
