down side to gears?
Old Aug 17, 2010 | 01:29 PM
Joisey's Avatar
Originally Posted by 07BLUEJK
Maybe look at the 4.56's with the 33"s
someone has a set for cheap cheap in the fs section. pick them up !!!!
Old Aug 17, 2010 | 04:07 PM
Rub61's Avatar
Originally Posted by Red Dog
That drive shaft is going to be spinning at an RPM that it is not designed for. This does not mean you will have a problem. But you might.
High RPM drive shaft would concern me also if you get to radical with the gearing.
Anybody out there have problems with drive shaft speed???
Old Aug 17, 2010 | 04:12 PM
nthinuf's Avatar
There are some threads about blown transfer cases that you can search around for. No concrete evidence, but one train of thought is that larger tires + lift + aftermarket driveshaft + bad pinion/driveshaft angles may have been the cause. Read through them and form your own conclusions...
Old Aug 17, 2010 | 04:14 PM
Biff Malibu's Avatar
There is no downside to 5:13's
Old Aug 17, 2010 | 04:16 PM
Brashanic's Avatar
unless, after you put in 5:13 you decide you want 5:38
Old Aug 17, 2010 | 05:42 PM
Wheelerbob's Avatar
I don't think drive shaft speed should be much of an issue, my auto came with the little 28" tires and 3.73 gears. I would think that 5.13 on 34 or 35" tires would have about the same drive shaft speed as mine did stock, ( give or take a little )
Old Aug 17, 2010 | 05:58 PM
Originally Posted by Brashanic
unless you after you put in 5:13 you decide you want 5:38
Just like me........
Old Aug 17, 2010 | 06:06 PM
HV's Avatar
HV
so you would of gone with 538s from the get go
Old Aug 17, 2010 | 06:12 PM
nthinuf's Avatar
If I had a Rubi, I would have gone 5.38's without a second thought. Damn D30...
Old Aug 17, 2010 | 06:24 PM
Brashanic's Avatar
if i could do it again.
