Drag link flip or drop pitman arm?
Old Aug 4, 2016 | 02:38 PM
  #21
jadmt's Avatar
JK-Forum Ambassador
Originally Posted by blidds
I forgot to add that after I put my wheel spacers on the wobble got worse
Did you remove the rotor retainer clips?
Old Aug 5, 2016 | 08:16 AM
  #22
kjeeper10's Avatar
Vet Army
Old Aug 6, 2016 | 07:19 AM
  #23
blidds's Avatar
I did not remove them
Old Aug 6, 2016 | 09:13 AM
  #24
blidds's Avatar
would that make it have a wobble
Old Aug 6, 2016 | 10:00 AM
  #25
jadmt's Avatar
JK-Forum Ambassador
Yes it means your rims may not be square on the hubs. Notice I said may. All spacers mnfg should have that in their instructions I know spidertrax does.
Old Aug 6, 2016 | 10:01 AM
  #26
Monte417's Avatar
Yes. The wheel is not mounted properly (flush) against the rotor
Old Aug 6, 2016 | 11:32 AM
  #27
nthinuf's Avatar
The wobble got worse. Meaning, this is not the 'only' thing that is going on.
Originally Posted by nthinuf
Before you run out and throw money at it, my suggestion would be to read through Planmans deathwobble/shimmy diagnosis thread (stuck to the top of JK Writeups section).
In addition to removing the wheel stud retaining clips, you really should diagnose the issue and try to figure out what else is loose or worn out. Sure beats throwing money at part after part and hoping you eventually pick the right one...
