Drag Link Rattle
Old Jun 8, 2016 | 06:07 PM
Plendl's Avatar
Default Drag Link Rattle
There is a loud rattle or clanking sound when I go over a bump. I have checked the forums on here and some say it is loose shocks control arms and drag link and tie rod. I have checked all the above and all are tight but drag link. I can rotate it by hand easily and recreate the rattle sound. The tie rod will rotate too but not as easy as the drag link. I had a rough country 3.5 inch lift installed and they put a drop pitman arm on. So far I have upgraded to fox 2.0 shocks and fox ats steering stabilizer and have a set of 3 inch Evo springs on order. I'm kinda planning on putting stock pitman arm on when I put the springs on from what I have read is that everyone says to put stock back on that the drop is hard on things. My question is should I be worried about the rattle? Do I just deal with it? If I upgrade it I was looking into a drag link flip kit. If i do that what are benefits and what brand is best. Another option I have is I still have warrantee on the jeep and take it to dealership and have them look at it and replace it. What do you guys think. Thanks
Old Jun 8, 2016 | 10:43 PM
LOLO9293's Avatar
Subscribed. Have the same problem when I reverse down my drive and hit the small curb and bumps. Couldn't tell what it was though. But I know I do need a new draglink. Maybe that why.
Old Jun 9, 2016 | 12:30 AM
sa29560's Avatar
New drag link end is cheap, buy a stock replacement. Takes 30 minutes to swap out.
If you plan on going bigger buy a better drag link.
Old Apr 20, 2020 | 05:34 AM
Jessez14JKU's Avatar
Any luck fixing this problem? Mine is doing the same thing.
