Draglink Flip Kit
Old Mar 3, 2013 | 05:53 AM
hskr's Avatar
Default Draglink Flip Kit
EVO or Synergy any recommendations?
Old Mar 3, 2013 | 10:45 AM
tlminh's Avatar
Just curious. What is the purpose of these? Hard install?
Old Mar 3, 2013 | 11:06 AM
Staytru06's Avatar
Correct castor after a lift, help with keeping your steering feel more like stock. Many ppl with do a dropped pitman arm which is a very bad idea.
Old Mar 3, 2013 | 11:22 AM
abqtj's Avatar
How does that correct castor angle?
Old Mar 3, 2013 | 11:24 AM
Doesn't do anything for castor. After a lift it places your trac bar and drag link parralel so they operate in the same arc and you don't end up with bumpsteer. Uusally not needed unless lift is great than 3.5 inches. You also need to be aware that if you flip the drag ling you either need to raise the trac bar at the axle or drop it at the frame. I am going with synergy, some vendors just repackage a chrysler right hand drive drag link. Synergy makes a beefier rebuildable, greasable drag link.
Old Mar 3, 2013 | 11:30 AM
Jeepin Dad's Avatar
I just helped a friend install the Synergy draglink flip and track bar relocation bracket on his Jeep yesterday. The Synergy componets are beefy. The install wasn't hard, the most difficult part was gettting the stock draglink to release from the pitman arm. One issue we did run into was his BDS swaybar disconnects wouldn't work with the track bar relocation bracket, there was not enough room between the stock tab and the bracket to get them on and off and they were to long to mount on the upper hole on the bracket. We ended up putting a set of stock links on for now.
ID:	429082   Click image for larger version
Old Mar 3, 2013 | 01:10 PM
kjeeper10's Avatar
Vet Army
X2 Synergy
Evo uses a right hand drive drag link.
ID:	429132   Click image for larger version
Old Mar 4, 2013 | 08:44 AM
chris@offroadevolution's Avatar
Sponsoring Vendor
We are a vendor for both, let me know if I can help you with anything
Old Mar 4, 2013 | 10:05 AM
sburggsx's Avatar
So all there is to a flip kit is a replacement drag link, and a track bar bracket?
If you're already having work done that's going to move the track bar, (Artec trusses for instance) then all you're looking for is the replacement drag link?
Old Mar 4, 2013 | 10:22 AM
Scallywag's Avatar
Originally Posted by kjeeper10
X2 Synergy
Did you have to to any modifications to make the Synergy work with 15's?
