Drive shafts
Old Oct 11, 2014 | 06:22 AM
  #21
jk958's Avatar
Been using 1310 TW front 1350 rear. No problems
Old Oct 11, 2014 | 06:35 AM
  #22
sea bass's Avatar
Coast for me too.
Old Oct 11, 2014 | 06:52 AM
  #23
JE8154's Avatar
Coast front Adams rear, no complaints.
Old Oct 11, 2014 | 06:53 AM
  #24
sm_rubi's Avatar
I've run the Coast shafts in the past, custom DS and now Adams. have to say I'm impressed with the quality and customer service of the Adams DS!
Old Oct 11, 2014 | 07:07 AM
  #25
Biginboca's Avatar
No one runs Tatton? I ordered a Tatton front last week and am waiting on it to arrive, surprised no one is using one they seem competitively priced...
Old Oct 11, 2014 | 08:28 AM
  #26
CerOf's Avatar
Question for the Adams and Coast driveshaft owners do you have to periodically take a grease gun to those shafts? Or are they like the stock ones and don't have too.... My Tom Woods you grease up yourself periodically .... Thx
on the Adams, maybe, maybe not. Depends on the options you go with. The slip joint has a zerk to grease with each oil change. Otherwise, depending on your options, you may have sealed ujoints that you don't grease. Pros/cons to both.
I went non-greaseable. My reason? Low maintenance. The bad? Only last 50k miles or so then I'll have to replace the ujoints. Greaseable are supposed to last longer, especially if you go offroad a lot.
Adams only use neapco or spicer joints so GOOD quality.
Reel and Coast use neapco or spicer too.
Tom Woods uses a cheap brand that have shown to fail; however, you can pay more for a neapco/spicer joint.
Tom Woods, Reel, and coast were more than Adams when I bought mine.
Sent from some string and a few tin cans.
Old Oct 11, 2014 | 10:00 AM
  #27
sm_rubi's Avatar
All aftermarket DS I've run required servicing but it's super easy not hard at all. A good rule of thumb is to do it after doing water crossings or mud after getting it all cleaned up. Also, it's a good idea to have any aftermarket DS check for balancing periodically. Used to do it every 12-18mos at a cost of about $60 at a local driveline shop.
Old Oct 11, 2014 | 10:54 AM
  #28
71T37's Avatar
I been running a Tatton in the front for 2 years now and I have had no problem with it at all. I Just order a rear one from them to go with My new lift. It comes with the yokes too.
