Driveline modification with lift?
I'm looking at a 4" Teraflex lift and keep reading I will need to do a driveline modification and don't know what all is or will need to be involved with this. Any and all advice is appreciated.
Thanks
Thanks
That is a 5-6" lift, depending on model and added weight. There are variables involved, but generally, 3-4" is about where you should start worrying about new driveshafts. As stlfan06 mentioned, start with the FAQ's:
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
Both the Suspension and Drivetrain faq's talk about driveshafts. And this bit in the suspension faq is a good one:
Q: What are all the components that I will need with a 4" lift?
And the notes for that lift have the caution right in them, so it shouldn't be any major surprise...
And the install guide:
Drive shaft modification required for 2 door models and highly recommended for 4 door models.
Driveshaft Notes:
The design of the factory driveshafts is great for highway use and mild off road use, but may not survive the rock contacts and stresses of moderate to extreme off-road use once the vehicle is lifted 3 inches or more. TeraFlex driveshafts and yokes are available separately.
front driveshaft - all Part# 4743200
rear driveshaft - automatic 2door Part# 4744200
rear driveshaft - automatic 4door Part# 4744400
