Drivers side front spring spinning out of perch
Old May 1, 2009 | 06:49 AM
69thunderbird's Avatar
Default Drivers side front spring spinning out of perch
My drivers side front spring spinning out of perch - does anyone sell a strap or pre fab part to weld on and pin it down?
Name:	Where the spring is supposed to be.JPG
ID:	23330   Click image for larger version
Name:	Spring out of Perch.JPG
Old May 1, 2009 | 06:58 AM
wayoflife's Avatar
JK-Forum Founder
sounds like your shocks are a bit on the long side and your coil is unseating at a full droop. you might be able to fab up a spring retainer like the old tj's had. all you need is something like a small conduit clamp and a self tapping bolt and you're golden.
Old May 1, 2009 | 07:04 AM
Default thanks
thanks WOL - great idea!
