View Poll Results: Which Driveshaft Manufacturer
Coast
27.78%
Teraflex
0
0%
J.E. Reel
16.67%
Tom Wood's
55.56%
Multiple Choice Poll. Voters: 18. You may not vote on this poll
Which Driveshaft???
Old Apr 27, 2011 | 07:28 PM
RN M OVR's Avatar
Default Which Driveshaft???
My Jeep has over 3" of lift (3.5" or so). It's a two-door automatic. I can't go without 4-wheeling much longer. Besides, with the summer coming up, I plan on many camping trips and I want to have some fun with the Jeep too. Right now it's running stock shafts both front and rear. I have front lower adjustable control arms already installed; just ordered rear upper control arms from Northridge to fix the rear pinion angle.
QUESTION: When installing a front driveshaft, do I need front upper control arms too or am I fine without them?
Anyway, there are some very reputable manufacturers out there but I don't know who to really purchase from. I personally have been debating Teraflex vs. Coast, but I am of course open to suggestions and facts. So aside from voting in the poll, feel free to say why a certain manufacturer orwhat you are running and why you went that route and/or how are those shafts holding up for you.
Thanks!
Old Apr 27, 2011 | 08:03 PM
jksteve89's Avatar
Just installed my coast driveshafts last week. I have a 3 inch old man emu lift on my 2 door. I have adjustable uppers and lowers front and rear. I installed the front shaft on friday and drove it home (down the highway at 70 mph) with no vibes. When i did the rear on saturday i got some vibes do to the angle it was at so i adjust the rear pinion angle but no the front. I am getting some interference with the rear jks track bar and the rear passenger side spring (do to adjusting the rear pinion angle) so i ordered rockcrawler coil correction wedges and jks rear spring retrainers from northridge.
Old Apr 27, 2011 | 08:26 PM
GCM 2's Avatar
Default E) all of the above
All the manufacturers you have listed are the top choices, so unless you have a personal preference, any of the listed choices is a quality component. I run J.E. Reel's, however Tom Woods makes about the prettiest drive shaft, not kidding, they are really nice to look at, I'm just saying. So if is pretty is a criteria, then Tom Woods is the winner
Old Apr 27, 2011 | 10:13 PM
nthinuf's Avatar
You'll be fine with just the front lowers. Add the uppers later if you want to move the entire axle forward/backward in the wheel well.
Old Apr 27, 2011 | 10:34 PM
Red Dog's Avatar
What really matters is how it is made. Are they using quality parts to build the drive shaft from, are they replacing the yokes. I think that these companies are all good quality places and more than likely the drive shafts are very similar in construction. You can pay a lot for a name and let’s face it this is not rocket science. Just don’t buy crap to save $50. My vote is “none of the above”.
Old Apr 27, 2011 | 10:39 PM
wayoflife's Avatar
JK-Forum Founder
Thanks!
you only need adjustable upper control arms to set your REAR pinion angle. up front, there really isn't a whole lot you can do except find a balance between good positive caster and keeping vibrations at bay. as far as manufacturers go, drive shafts are pretty much drive shafts but, i would recommend that whoever you go with, you ask for spicer u-joints. some of the manufacturers out there use cheap chinese u-joints and i wouldn't waste your time with them. for the affordable cost and the fact that they come with spicer joints, i personally would recommend going with coast.
Old Apr 28, 2011 | 05:44 PM
RN M OVR's Avatar
Thanks for all of the replies everyone. What causes vibrations when installing new driveshafts? If I don't have [noticeable] vibrations now with my stock shafts, is it still possible that I may get vibrations with the new ones? If so, why?
Thanks!
