driveshaft angle without angle finder?
I have 3 inches of lift. I had similar problems as your having. If your bottom rear control arms are too long that's your issue. Cut your pinch seams and shorten your rear lowers and I know this will help. Also if you put in a rear adj trackbar it helps with rear diff clearance and that trackbar bracket will not be rubbing!!
