driveshaft help
Old Feb 21, 2010 | 01:45 PM
awdspider's Avatar
Default driveshaft help
i was given a front driveshaft from a friend that was on his rubicon.
i have a 2 part question:
first question is i have a sahara, will the t.c. yoke that came with the driveshaft work on my t.c. ?
second: does anyone know what the bolt size is for the said t.c. yoke to u joint is (4 bolts).
he said it was a je reel driveshaft if that helps.
shaun h
Old Feb 21, 2010 | 04:05 PM
awdspider's Avatar
bump........
Old Feb 21, 2010 | 04:06 PM
wayoflife's Avatar
JK-Forum Founder
so long as it's a stock drive shaft, it will bolt right up to your axle and t-case. as far as the 4 bolts on the pinion flange goes, you will need a 15mm socket for them
Old Feb 21, 2010 | 04:57 PM
awdspider's Avatar
maybe this will help
this is the shaft
i need to attach this
to this
but i dont have the bolts
does that help?
Old Feb 21, 2010 | 05:07 PM
wayoflife's Avatar
JK-Forum Founder
aha, you need output shaft yoke bolts. unfortunately, if i recall correctly, you will need grade 1/4" coarse thread grade 8 bolts that are 1" long. you will need a 1/2" wrench to install them.
Old Feb 21, 2010 | 05:25 PM
awdspider's Avatar
cool thanks,
i will stop by the nut and bolt shop tomorrow. will that yoke fit on my transfer case.....it came off a rubi
Old Feb 21, 2010 | 05:33 PM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by awdspider
cool thanks,
yes. if i recall correctly, you will need a 1-1/4" socket to remove the flange nut and a gear puller will help you to remove the output shaft flange.
