Driveshaft help.
Old Apr 9, 2012 | 08:55 PM
Sirisa0408's Avatar
Default Driveshaft help.
Ok so i know there are a ton of driveshaft threads but i couldnt find the right answers. About my rig. 2010 2 dr rubicon. I installed a 2.5" spacer at the front 2" at the back. I have longer sway links at rear, stock rear at front. I wheel a good bit. I dont want to damage the driveshaft. Do i need to replace it with this lift set up before i damage it. Also i have 2.5" springs i could swap out with spacers and rubi springs for safety reasons. Also it is an auto.
Old Apr 9, 2012 | 09:48 PM
2012jkunlimited's Avatar
You don't HAVE to replace it. I'd just wheel it until you break it then replace with an aftermarket one. That's my plan. Just wheel until I break something then upgrade!
Old Apr 10, 2012 | 03:21 AM
Sirisa0408's Avatar
I would rather not damage it since i am keepimg all my stock items. Will it get damaged as it is now?
Old Apr 10, 2012 | 03:43 AM
pfd1980's Avatar
eventually you will tear the boot flexing out and it will start spitting grease up towards the tcase
Old Apr 10, 2012 | 03:59 AM
jknit's Avatar
The torn boot comes from offroad flexing right, everyday daily driving won't do much
Old Apr 10, 2012 | 04:34 AM
John_Mora's Avatar
If you dont disconnect your front links, you are good to go. Dont need to change your drive shaft.
Old Apr 10, 2012 | 07:13 AM
Bradlybob's Avatar
Veteran: Navy
Yep, the torn boot happens when you flex the pass side up or the drivers side down, usually with the sway bar disco'd. You should be fine if you're not wheeling hard.
Old Apr 10, 2012 | 07:46 AM
Full-Traction Suspension's Avatar
Former Member
You should'nt have an issue. Just know when it does break. It can not be fixed, and your not driving it home.
Old Apr 10, 2012 | 07:54 AM
nate_every's Avatar
I broke my front shaft after getting stuck in the snow this year. Stock height. I don't think that you will have a problem, but I would disagree with the guy who said just drive it till you break it. I was spinning when mine broke and the front half smacked into my tranny and put a hole in the bell housing...expensive, annoying, and outrageously frustrating. For the price of my repair, and I got away pretty easy on the price, you could upgrade both shafts and not worry about it. The problem is the slip yokes
ID:	302069   Click image for larger version
ID:	302070   Click image for larger version
Old Apr 10, 2012 | 12:25 PM
Sirisa0408's Avatar
So if i wheel. And keep my sways connected. I will be fine. Also would the lift cause it to get damged quicker if it will get damaged. I have about 3" of lift but have a 2.5" lift i can swap out for
