driveshaft help!!
Old Mar 22, 2013 | 11:28 AM
WYO-JK's Avatar
Default driveshaft help!!
Hey guys i got new driveshafts front and rear from coast and i cant get the stock rear to come off of the rear end.....I've hit it with a punch and hammer in the non threaded holes and nada.. I need your help!!!! Lol
Old Mar 22, 2013 | 12:58 PM
ronin2120's Avatar
Vet Army
I ended up using a a gear puller (I think thats what its called). You need to be careful and ensure that the teeth are equal on all three sides. Then I used an old large socket as a base plate for the center screw. The teeth kept slipping so I ended up using a ratchet strap to keep the teeth from slipping. This technique worked for me but it was very slow going and required a lot of breaks.
Old Mar 22, 2013 | 01:03 PM
jeffj's Avatar
Unhook the transfer case side first than pull the drive shaft from that end towards the rear tire. That will give you a lot of leverage and it should come out. Work it back and forth from the loose end.
