Driveshaft help
Hey, I'm new to this thing but I need help. I have a 2010 jk with a skyjacker 5.5 lift and I think I need a different drive shaft, like a longer one, is there anyone who can give me some advice on this matter?
Yeah you definently need a new drive shafts, I believe you need a 1310 driveshaft, check out northridge 4x4. They've got tons of options and all the info you'll need
awesome, thanks alot guys, I reviewed the adams drive shafts and I saw that they are cv shafts. Does that mean I'm going to need something extra to be able to adjust the diff angle.
Your differential or "pinion angle" is adjusted by your control arms. I'm assuming that at 5.5 inches of lift that you have adjustable control arms. As far as the driveshafts go, you are going to swap out the yokes and bolt in the new shaft. Pretty basic.
Tom Woods, had nothing but great experiences!
Tom Wood's Custom Drive Shafts - Tom Woods Custom Drive Shafts Custom Driveshafts Specialist
There are also a couple writeups showing how to swap the yoke/flange for the new shaft up in the writeups area. An index is at the top.
