Which driveshaft, and why?
I went with JE reel because they were sold by the place I bought my lift from. Like the others have said reel/Adams/woods/coast all quality can't go wrong with any of them. Just stay away from cheap stuff.
This topic has been discussed probably a thousand times. They are all the same using the same components. If you search you'll find a thousand posts recommending whichever shaft that poster is running, lol
I'm running 2 aftermarket shafts from 2 different manufacturers. Each was the best priced one when I happened to be shopping.
This
Same shit, different stickers. Who's can you get the cheapest on the day that your ordering one. That is the best one.
Agree'd, locally here with spicer joints and cost all of $300.00 ea vs $450-$700 on line from "specialty" shops.
What's the difference between a 1310 and a 1350? I noticed on the Mopar driveshaft they supply with their recent 2in and 4in lifts, they're both labeled as 1310 shafts but different P/Ns between the lifts.
The 1350 setup uses 1350 series U joints closer to 3.6" wide with larger caps, bodies & journals.
1350 joints can operate at more severe angles and at a higher load. 1310's are pretty tough, if you have good driveline angles a well balanced shaft can handle 37's. Also depends on how hard you are on your rig.
1350 stronger joints
Factory driveshafts use joints that fall between these 2 in strength, but the shaft tubing itself is very thin and weak, damages easily. Also the operating range (usable driveline angles) on the joints is less.
In addition to what the two posts before this said, people typically run a 1310 series in the front and a 1350 series in the rear.
