Duratrac run small but this is crazy
Old Aug 6, 2013 | 11:08 AM
stevedolce's Avatar
Default Duratrac run small but this is crazy
I'm running 315/75/16s at about 35psi. Just reassured my tires to calibrate my flashpaq and they measured a little over 33 INCHES!!!! Jeez...
I've got about 38k miles on my tires--
Can other GYDT owners post up their tire hight??
Old Aug 6, 2013 | 11:18 AM
planman's Avatar
Forum Tech Advisor
Depending on wheel width and weight of your rig, most tires measure 1"-1.5" less than the labeled size when mounted and on the ground.
Most 35s are around 34.5" unmounted and around 33.5" mounted when brand new. Some are a little taller and some are a little shorter.
Duratrac 315/75/16s are reported to be 34.6" unmounted and new, but I'd bet that actual specs vary a little.
It would not be surprising that a 35 with 38k miles would measure close to 33" if the wheel was wider than 8" and he rig was on the heavy side.
Old Aug 6, 2013 | 11:20 AM
dodgeman70592's Avatar
315/70/17 DT on stock wheels measured 33.5" @ 32psi
Old Aug 6, 2013 | 12:08 PM
PG-JKU's Avatar
Yup, the 33's run small too, about 31.75. Still, amazing for what they pull me out of. I do wish they ran truer to size.
Old Aug 6, 2013 | 12:12 PM
loserhead4236's Avatar
my toyo mts only measure a 1/2 inch smaller on a 9 inch wheel with a pretty heavy rig. I think it just depends on the tire and materials used
Old Aug 6, 2013 | 12:24 PM
kjeeper10's Avatar
Vet Army
1-1/4 is norm mounted. Some tires more so less
stevedolce's Avatar
I really love the tires--but would like something a little more true to size when these are done.
Old Aug 6, 2013 | 12:25 PM
stevedolce's Avatar
What psi is everyone running? 33-35 range?
Old Aug 6, 2013 | 12:32 PM
JK UNLIMITED's Avatar
My 33" DT's ran about 33 1/4" at 32psi and a little bigger when I ran them at 40psi which I had to do to get the mileage above 11mpg and they rode just fine being a load E tire that was the recommended pressure! But my 35" MTR's run about 34 1/2"
Old Aug 6, 2013 | 12:39 PM
SBEII's Avatar
I'm running 28lbs in my KM2s. They measured about 33.8 when I had them mounted. If you want a true 35", get 37".
