Duratrack help !!
Old Sep 23, 2011 | 11:00 AM
Woodman506's Avatar
Default Duratrack help !!
Looking for some advice on tire and rim size combinations. I am thinking a 35" x 12" tire (Duratracks if possible) on a 16" x 8" black steel rim with 4.75" backspacing.
I have 2" of lift.
you guys think this will work? anyone have any pics?
thanks
Old Sep 23, 2011 | 11:25 AM
jktoy's Avatar
I have a 2&1/2 inch lift and 315/70/17 duratracs. And my wheels r 4.5 back spacing and either 8 or 8.5 wide. And I have no problems.
Old Sep 23, 2011 | 11:26 AM
JohnnyQuik's Avatar
Yep. This pic was when I still had a 2" BB. 16X8" wheels with 4.5" backspacing and 34.8" Duratracs.
Name:	hella covers.jpg
Old Sep 23, 2011 | 11:34 AM
Joe Boxer's Avatar
I have 2" of lift.
My intended setup is 315-70/17 DuraTracs on 17x8.5 wheels with a 4.25" backspacing. With your 2" lift, you may experience some rubbing... contingent on spring settling or weighty modifications like bumpers. I think you should be good to do with what you want to do, but keep in mind that you MAY need a 1" spacer lift or, maybe, just do a 1" body lift to mitigate any rubbing you may experience.
Old Sep 23, 2011 | 02:12 PM
Discount Tire's Avatar
Sponsoring Vendor
I have 2" of lift.
thanks
You might want to consider running a wider aluminum wheel. Most steel wheels don't clear the Jk brakes without a wheel spacer and running a slightly wider wheel will help you get more life out of your tires in the long run.
Let us know if we can help you with a package. We guarantee the lowest delivered price and shipping to the lower 48 states and Canada is FREE with pre-paid, duties, taxes and customs fees.
16" Wheel options: http://www.discounttiredirect.com/di...wd=16&rw=&fcb=
Old Sep 23, 2011 | 08:56 PM
wralston89's Avatar
I got black rock steel wheels 16x8 on my rubicon they have 4.25 backspacing and i run the 315/75/16 with 4 inch lift i love them great tire .... I dont know if 4.75 is enough or not i just played it safe no regrets i like them sticking out a little more
Old Sep 24, 2011 | 07:16 AM
ShiftySooner's Avatar
Default That will work fine.
315/75R16 on 16x8 Black Rock Dunes, 5" of backspace, 2.5" RC BB. No rubbing, ever. (even before chopped fenders)
Old Sep 24, 2011 | 07:20 AM
Don't know where this info comes from, but it seems inaccurate. Not heard of a case of 16" rims not fitting a JK, especially since they are std equipment on base models.
Also, correct air pressure will affect tire life much more than the width of the wheel. In reality, a narrower wheel will help hold a bead when aired down on the trail. I run 12 psi offroad on my 16x8 steel wheels.
