Dynomax 39459 - Issues
Old Apr 28, 2011 | 07:32 AM
speedy64vw's Avatar
I have not yet installed the system. I should be getting it Saturday or monday... Which I will be opening the box and crawling under my jeep to fit and install within minutes of greeting the ups man!
Will reply and pm ya when I install it
Old Apr 28, 2011 | 07:45 AM
Pluke the 2's Avatar
Not to knock their product as I like it a lot. And the sound is awesome!@
We just put their system on our 4 door Rubicon with a TF 3" Long Arm kit and we had to put spacers on the rear sway bar to avoid contact with the over the axle system.
Pluke -
Old Apr 28, 2011 | 08:20 AM
speedy64vw's Avatar
well, good thing they have a 90 trial period...we'll see how mine turns out- pics to come once installed or fitted?
Old Apr 28, 2011 | 09:30 AM
highwayman's Avatar
Couldnt justify spending the cash for the kit. I had my local exhaust guy (who has done outstanding work for me over 20 years) fab me up a cat-back exhaust w/dyno max muffler for 300 bucks. Im running a TF 2.5 coil lift w/the TF axle trackbar bracket & clearance was an issue w/the bump travel I wanted w/out using excessive bump stop lengths. We ran the exhaust up & over the rear axle like stock but trimmed it right before the TB. I didnt like the idea of the exhaust dumped down low in stream crossings like in the photo.
Old Apr 28, 2011 | 09:48 AM
racin444's Avatar
Glad you posted up this info of the Teraflex trackbar axle bracket hitting this rockcrawler kit! I think Im just gonna see how the muffler fits into the stock exhaust and then just remove the stock muffler.
Old Apr 28, 2011 | 10:10 AM
highwayman's Avatar
I ran my muffler right behind the cat, but went full cat-back. I didnt re-use the old plumbing.
Old Apr 28, 2011 | 11:57 AM
racin444's Avatar
Thats what I plan to do with mine except Ill try to reuse what I can with the old plumping. I like how it dumps out right above the rear axle without the muffler.
Old Apr 28, 2011 | 12:05 PM
Dynomax's Avatar
Sponsoring Manufacturer
Red face
That is not a bad cost for a custom setup actually. Glad it worked out for you going this route.
Old Apr 28, 2011 | 03:25 PM
highwayman's Avatar
Thx. Yeah since I knew I had different ways I wanted to go, I felt better going w/Scotty's for the install. Knowing they would be more then helpful if I needed to make changes to the exhaust as I modified the lift. The final product came out exactly as I wanted & the price was icing on the cake. The Dyno-max muffler sounds great BTW!
Old May 11, 2011 | 03:13 PM
DTJK's Avatar
Man just order it 2 minutes ago and now I see this. I have the Tera bracket too.
