E-Brake cable question
Old Apr 13, 2009 | 04:15 AM
UGOTKERN's Avatar
Default E-Brake cable question
07' Unlimited w/ 6" lift using JKS adjustable control arms. Passenger side e-brake cable will be stretched beyond max if I allow full flex due to the fuel tank.
So until I can come up with a solution I'm running shorter shocks which of course limits our flex.
Any suggestions?
And yes the tub bracket was removed long ago
Old Apr 13, 2009 | 08:29 AM
JKRockStomper's Avatar
just unbolt the e-brake bracket and let it hang. It will not go anywhere and should be fine for years.
Old Apr 13, 2009 | 12:24 PM
I see you said you already unbolted your bracket. I did the same thing but also rerouted the e-brake lines underneath the fuel filler tube so they would not get hung up when flexing.
Old Apr 13, 2009 | 04:48 PM
BlackNorthernJK's Avatar
Yup, unhook the cables and run them under that cross member, I re-bolted mine to the underside of that cross member
