E-Brake Dash Light
Ok, I can't figure out how to make the stuipd dash light go off!!! I did an axle swap to full width ProRock 60's and the dash light for the "BRAKE" is on with the e-brake off! In fact, I disconnected the ebrake cable from the axle and the light was STILL ON!!
I can pull the e-brake and the light flashes...can someone tell me where the sensor is that controls this light or have ANY idea how to make this annoying light go away!?
have you checked the fluid level in your master cylinder. a brake light on in this manner typically means you're low on fluid. if that doesn't do the trick, you may have to take your jeep to the dealership and have your brakes power blead using a scan tool.
I connected my Superchip programmer to check any DTC codes and I had two codes. The two codes were front driver and front passanger speed sensors not working. I knew this already, as my ABS sensors are not installed...would this cause the "Brake" light to come on as well? I cleared the DTC codes with the superchip programmer...
BTW, I LOVE the programmer as troubleshooting the complicated computer is GREAT (especially in a state were emissions are required).
Thank you for the input and suggestion, but I just went out and topped off the brake fluid and that didn't fix the problem.
*Edit..
Ok, i reconnected and adjusted the ABS sensors up front and WHULA!!! IT works!! Thank you wayoflife. I was worried that I would be fighting electrical gremlins for ever.
