E-Disco on an X
Old Jan 29, 2011 | 04:43 AM
jjndadJK's Avatar
Default E-Disco on an X
Has anybody put an E-Disco from an Rubicon on a non-rubicon? I was thinking about putting one from a 07 Rubi in my 07 X. It looks pretty straightforward if I look at the instructions for installing a new one from Mopar. Looks like all I would need is the wiring harness (wonder how much that goes for) and a switch ($40 from Quadratec). Am I missing anything?
Old Jan 29, 2011 | 05:14 AM
strokemyego416's Avatar
i'm sure youd need a flash of some sort to get it working correctly.
Old Jan 29, 2011 | 05:16 AM
jjndadJK's Avatar
That is correct. I did see that in the instructions.
Old Jan 29, 2011 | 05:25 AM
do you have someone selling you one already? and if so how much are you buying it for? just out of curiousity.
Old Jan 29, 2011 | 05:26 AM
mhaines's Avatar
Did that on my 08X, bought a Rubi chassis harness and switch pod from quadratech. After I installed the harness and the smartbar I took it to the dealer and had them flash the computer to turn in that feature. Works great! I think the harness was #52446.111 and was $75
Old Jan 29, 2011 | 06:23 AM
dmhines's Avatar
I installed one on my X. Came out of a Rubi. Seller cut the harness out of Rubi and included it.
Dealer enabled it for me and I got the buttons from Quadratec.
Old Jan 29, 2011 | 12:50 PM
jjndadJK's Avatar
Thanks for the great info, especially the part #'s.
Old Jan 31, 2011 | 07:02 PM
jjndadJK's Avatar
i have one on the way. Any words of wisdom for the install?
thanks again.
Old Jan 31, 2011 | 07:44 PM
mhaines's Avatar
thanks again.
If you are doing it in the garage with no lift, I highly suggest you stretch! You can get to everything but you have to be very bendy, lol. I laid the harness out on the ground first before I started feeding it through, kinda helped. When you take off your original, pay close attention to how it runs along the frame, itll save you a little aggrevation. There are a few hidden push pin retainers toward the rear, just break them it's easier that way.
Old Jan 31, 2011 | 07:48 PM
JK.nick's Avatar
Make sure you install it flipped! Don't want that pesky motor breaking on a rock or something
