E-locker Question / Consideration
Old Dec 8, 2014 | 05:32 PM
ibjeepin2's Avatar
Default E-locker Question / Consideration
Hi all, I have a 2010 JK Sport with a stock 44 Dana in the back and stock 30 up front. Its my daily driver and will be moving up to some new 295/70r17s before long over the stock 255s. I'm not planning on re-gearing as I will not go any bigger on this rig (have another for that . Question: I'm considering installing a e-locker of some type up front since the rear has the dana 44. I've taken it off road just a couple times as it's an auto (and my daughter cannot drive a 5 spd - yet anyway...) gets her drivers license next month - but we'll work on that in my YJ.
I live in central illinois and since the snow can be bad at times, I didn't want to go with a manual locker such as a aussi. That way I can utilize the locker only when needed on occaision when we had to the trails a couple times a year in it.
I Know Auburn makes one - ECTED and Eaton makes one as well. For the trail riding we do in my daily driver, I prob really don't need one, but would be nice to have a little piece of mind.
Any input or suggestions would be appreciated along with how much work is involved in the install.
Thanks all -
Truly appreciate any input, concerns and warnings....
Old Dec 8, 2014 | 05:36 PM
htm7765's Avatar
Interested in your responses I was thinking of doing the same thing e-locker up front an installing a Tru-lock in the rear
Old Dec 8, 2014 | 06:01 PM
nthinuf's Avatar
All of the full case units will take as much work as installing gears. If you are not up to doing the gears yourself, start talking to a few shops.
https://www.jk-forum.com/forums/jk-w...gearing-82262/
This is a decent locker overview. (the d44 eaton has been upgraded to 4-pin since this was written)
Project-JK.com - Jeep JK Wrangler Resource » Dynatrac Presents - Lockers 101
Since you don't really need thousand dollar selectables, read through a few threads on the Detroit TrueTrac.
Old Dec 8, 2014 | 07:48 PM
2climbbig's Avatar
Auburn locker is actually a clutch pack and therefore will wear out. The eaton locker is a real locker and a much better product.
Old Dec 8, 2014 | 08:19 PM
Yamaha90's Avatar
If you are questionong the wiring of an electronic locker, i detailed the wiring in my thread below.
https://www.jk-forum.com/forums/jk-w...ite-up-305433/
Old Dec 8, 2014 | 08:27 PM
genesis121's Avatar
This is the exact set up I have on my 2010. The only issue I have had is with the front Eaton e-locker wire connection. The water proof connector Eaton uses does not make a good connection and the locker will not engage. I have been fighting this for awhile. Now with the TruTrac in the rear, I love it. It engages well and works great with the ESP. Just note they recommend NOT using a synthetic oil in it.
Old Dec 9, 2014 | 04:43 AM
2climbbig's Avatar
can you send us a picture, perhaps we can help.
Old Dec 9, 2014 | 03:19 PM
ibjeepin2's Avatar
Thanks everyone for the input. Greatly appreciated.
