E Locker working?
Old Jul 23, 2013 | 06:57 PM
genesis121's Avatar
Default E Locker working?
I recently installed a Eaton E Locker on my Dana 30 front axle. This might sound like a stupid question by how can I tell if it is working or not? I found a little dirt area near my house, went into 4 Hi and flipped the switch. I could feel that the 4 wheel drive was engaged but how do I know the locker is engaged? I thought I would feel it in the steering, or even hear the locker engage?
Old Jul 23, 2013 | 07:17 PM
v8zracer260z's Avatar
Veteran: Marine Corp
If the locker is engaged your turning radius should be like a truck much wider than when unlocked.
Old Jul 23, 2013 | 07:39 PM
TokenMSJ's Avatar
Shouldn't have to even be in 4WD.. Hit the switch, turn left and go.. Look out the door, is the tire in front of you kicking up a lot of dirt..?? Is it HARD to hold it turned..? If so, you're locked.. If not, you're not
Old Jul 24, 2013 | 06:22 AM
Monte417's Avatar
I thought you had to be in 4wd for the front locker to engage
Old Jul 24, 2013 | 06:41 AM
Silver Bullet's Avatar
That is correct. Transfer case must be engaged in order for power to be delivered to the front axle.
Old Jul 24, 2013 | 07:03 AM
bigchelis's Avatar
Yep, put it in 4wheel drive.
Make a turn a full 360 degrees over and over like I do. If it works you will feel the steering stiffen up and as if you are driving a bus..
Currently; mine is not working though.
Old Jul 24, 2013 | 07:15 AM
Monte417's Avatar
when your locked up careful with the turning thats how i snapped my trackbar
