EGR valve block off
Your thread title suggests you are thinking of disabling or blocking off your EGR system.
You would have to come up with a way to fool the computer into thinking the EGR system is functioning properly. This is how it checks the system on US JKs:
After the EGR monitor conditions are met, the EGR valve is turned on and off momentarily. The EGR monitor calculates the difference in engine roughness from the EGR off condition to the EGR condition. This engine combustion stability difference as measured by engine roughness is the measure of a functional EGR system.
No,my EGR works well but I don´t like EGR system in cars. It´s like eat my own sh*t
. And I think also,it steal a power.
I've been thinking not just unplug conector(I know,it is controled by computer) ,but put in some block off plate betveen EGR and tube.
. And I think also,it steal a power.I've been thinking not just unplug conector(I know,it is controled by computer) ,but put in some block off plate betveen EGR and tube.
Therefore, if you block it off, it will throw a code and turn on the MIL. The code will most likely be P0401.
If you read post #3, you will see the computer knows if the EGR is working or not. I don't mean just opening and closing. It knows whether or not it is actually feeding EG into the intake.
Thanks! I understood
Now if you where talking Diesels.
Now when it was running that thing could move! Mybe it was turned up just a little or alot
