Shrocks install?
Old Jan 16, 2009 | 09:10 AM
sully151's Avatar
Default Shrocks install?
Can a moderately mechanically inclined and a not so mechanically inclined install Shrockworks rails without too much difficulty?
Old Jan 16, 2009 | 09:13 AM
Littlejon's Avatar
As long as you can folow these instructions you should be fine.
Old Jan 16, 2009 | 09:48 AM
leros's Avatar
i'd suggest doing it w/ someone else. An extra hand will sure make your life easier.
Old Jan 16, 2009 | 11:01 AM
Mark Doiron's Avatar
Yes, but not having that available (doing the mod on a workday for most folks, but I'm retired), I used the box that the rails were shipped in to hold up one end while measuring, drilling, etc at the other. It worked out fine, by myself. But, do be careful about what size holes you drill where. I got mixed up and drilled the wrong size hole for one bolt. Shrockworks came through with an extra stick/strap nut to take care of my mistake--no extra charge. BTW: Frame is tough to drill through--and I was using cobalt bits!
Old Jan 16, 2009 | 12:41 PM
seer1's Avatar
Originally Posted by SONIC
the frame is THICK in spots and its a BITCH to drill through lol. (without a right angle drill...get one)
X2 on that. Also pick up the unibit as well. It'll cut your cursing in half. I have a long arm floor jack and that really made holding it up much easier.
Old Jan 16, 2009 | 01:43 PM
vs_jk's Avatar
Definitely get the unibit and an extra set of hands.
Old Jan 16, 2009 | 02:02 PM
JKGirl's Avatar
whats all the fuss? Hubbo put mine on all by himself
He must be a real man No fancy tools or nothin'
Old Jan 16, 2009 | 02:09 PM
Screamin Lizard Customs's Avatar
Sponsoring Vendor
It can be done. We install them all the time just take it slow.
Gerry
Old Jan 16, 2009 | 02:13 PM
Piginajeep's Avatar
no kidding, i snapped a couple new bits in half installing my long arm kit...
The frame towards the rear wheels is doubled up.
Old Jan 16, 2009 | 02:19 PM
dlincoln91's Avatar
x8 be very carefull when drilling through the frame, my friend was helping me drill winch plate holes and the drill bit jammed at the end of the hole and the drill spun around and hit him in the head
man honestly i would wait and have a friend, i get really frustrated when things dont work out hte first time and friends help keep you calm and make it a good time so i would just have hlp
