Emergency brake help please
Trying to install a lift and I am wondering whats the easiest way to disconnect the emergency brake cable from the rear drums and axle brackets so I can reroute them to below the frame cross member.
may I ask what kind of lift your installing that you need to disconnect the e-brake?
I'm not sure whats invovled with disconnecting them from the rear brakes, but without looking at anything first, i would guess its easier to disconnect them from the e-brake handle side. There is usually a bracket designed in there somewhere for taking the slack out of the e-brakes, that would prolly be the easiest point if thats how its setup. good luck
