Emergency brake help please
Old Mar 14, 2007 | 09:07 PM
jeepit's Avatar
Default Emergency brake help please
Trying to install a lift and I am wondering whats the easiest way to disconnect the emergency brake cable from the rear drums and axle brackets so I can reroute them to below the frame cross member.
Old Mar 14, 2007 | 10:43 PM
Piginajeep's Avatar
may I ask what kind of lift your installing that you need to disconnect the e-brake?
Old Mar 14, 2007 | 10:49 PM
jeepit's Avatar
Superlift says to reroute your e brakes under frame crossmember...or should I not worry about it.
Old Mar 14, 2007 | 10:52 PM
yellowjeeper85's Avatar
I'm not sure whats invovled with disconnecting them from the rear brakes, but without looking at anything first, i would guess its easier to disconnect them from the e-brake handle side. There is usually a bracket designed in there somewhere for taking the slack out of the e-brakes, that would prolly be the easiest point if thats how its setup. good luck
Old Mar 15, 2007 | 03:00 AM
Renegade's Avatar
I just removed the bracket that held mine to the underside of the body tub. They seem to have plenty of slack and they don't get in the way of anything still.
Old Mar 15, 2007 | 06:18 AM
wayoflife's Avatar
JK-Forum Founder
How tall is this lift? If it's only 3", I can't see why you would need to do this.
Old Mar 15, 2007 | 06:30 AM
jeepit's Avatar
Superlift is a 4" kit.
