Engine light after evap relocation
Old Sep 29, 2008 | 05:41 PM
Strong Bad's Avatar
Default Engine light after evap relocation
I didn't disconnect the batter before relocationg my evap canister and got the gas cap light a couple of times then got the yellow engine light.
Any way I can reset the computer?
I am pretty sure it has been discussed here before, but I couldn't find it.
Old Sep 29, 2008 | 05:47 PM
wayoflife's Avatar
JK-Forum Founder
you can disconnect your neg battery cable for about 10 min and that will reset your computer.
Old Sep 29, 2008 | 06:01 PM
Strong Bad's Avatar
Don't want to sound stupid, but why just the negative? I have had the battery completely out and still have the problem.
Old Sep 29, 2008 | 06:23 PM
Leave Town's Avatar
Once you pull the negative cable you have broken the battery polarity. Pulling the ground is just the same as pulling the battery. It is also safer to remove the ground, as when you reinstall you don't have to worry and hitting something grounded with your wrench while on the pos post...
Old Sep 29, 2008 | 06:29 PM
Strong Bad's Avatar
Makes sense. Any guess as to why the engine light is still on?
Old Sep 29, 2008 | 07:11 PM
x No Compromise Offroad x's Avatar
Run the diagnostic, key on/off 3 times....most likely it wasn't the only code that got thrown out there....you may have others
Old Sep 29, 2008 | 07:20 PM
wayoflife's Avatar
JK-Forum Founder
exactly. there's a good chance that you have a "gas cap" code in there. also, if all your connections are good and you have no leaks, it'll actually go off on its own.
Old Sep 29, 2008 | 07:26 PM
jkboz's Avatar
My '07's check eng. light came on 2 times and took to dealer. They ended up finding a pin hole in the evap. line by the battery. Tne line is right next to the battery and rubs against it.
Checked my friends 4dr. and foun his was almost worn through also.
So maby check that at least a just in case?
Old Sep 29, 2008 | 07:50 PM
wrnglrguy's Avatar
Can you post a pic of this line to get an idea of exactly which one you mean?
Old Sep 29, 2008 | 08:24 PM
dyolfknip's Avatar
When you relocated did you properly re-seat the gasket on the evap canister? The green one about 2" in diameter inside of the twist off piece (sorry dont know the tech terms). If that isnt seated right you will throw a code, had it happen to a friend of mine. Seat the gasket on the canister side and re attach the twist off piece.
I just did mine last week and didnt unhook the battery (wasnt in Woods instructions) and have not had a problem since.
