Equal tire balancing compound? Anyone with experience?
apparently, the hub bore is 71.5 like you state, but my liquid metal gatlins have a bore of 87.1. Liquid Metal does not make a centering ring and so Discount Tire is having one custom made to accommodate my wheels. I am assuming that this should solve my issues with the vibrations?
I just think it is weird that you have the same issue on 2 set of tires using the same wheels.
Ok I think I understand, your wheels have a bore of 87.1. Discount Tire can have custom rings to convert your wheels from 87.1mm to a 71.5mm. I do not know if it would solve your issue, but having the wheels properly centered around the hub would sure help.
As a Mechanic, I would approach this problem your describing two ways. First, you need to rule out your front end. This can be done by raising the vehicle on a lift, engine running in 4wd (provided your vehicle has 4wd). Look (or have someone look) for bent wheels, broken belts/bands (internal tire defect), or anything out of the ordinary while tires are spinning. Note: if only one wheel wants to spin, from park, someone can hold the wheel that wants to spin, in order to force opposite wheel to turn. If all is well (or vehicle is 2wd)...
Second, watch (this is were protective hoods or covers get in the way) the spinning tire (no weights) on the balancer. It is possible to perfectly machine balance a bent wheel.
I would avoid full-time tire shops that let the "need for speed" to overlook properly balancing large tire sizes. Remember, they need quantity not quality to make a living. I routinely mount and balance all types of aggressive off-road tires up to 37" with no shimmy or vibration. Hub-centric or lug-centric makes no difference, in my experience.
Man, all my post's are long-winded!
Originally Posted by DTJK
Have you gotten the rings yet, did they help at all?
Might want to have the shop run a wheel on the machine without the tire and see if it is machined properly and not wobbly.
