ESP/ BAS Light came on
Old Mar 17, 2013 | 08:37 AM
xglenng's Avatar
Default ESP/ BAS Light came on
After installing a 4 inch lift on my jeep jk 2 door, i drove it about 50 miles down the road and noticed the ABS and traction control were acting funny, my guess is that i just need to adjust my steering wheel back to center, any other thoughts I'll keep ya posted with what happens when i correct my steering wheel today.
Old Mar 17, 2013 | 12:21 PM
kjeeper10's Avatar
Vet Army
Correct ......
Old Mar 17, 2013 | 01:33 PM
sm_rubi's Avatar
Originally Posted by kjeeper10
Correct ......
x2
most of the time.
Old Mar 17, 2013 | 01:55 PM
Huck271's Avatar
Also check front axle is centered. Sometimes after a lift is put in the front axle is off center and that effects steering geometry. Nothing worse than adjusting the drag link to find that the axle is off and when centered the drag link needs to be put back to the original position.
Huck
Old Mar 17, 2013 | 03:18 PM
dragonkj's Avatar
Damn I just had the same problem.I was worried I messed up the lines
Old Mar 18, 2013 | 03:44 AM
dragonkj's Avatar
So what might be some other problems that could cause it?
Typically it's the alignment?
Old Mar 18, 2013 | 03:57 AM
wildandwillin's Avatar
Most of the time after installing a lift. His sister and wheel alignment. I have had pinched cable to the sensors before. Let us know what you find
Old Mar 18, 2013 | 04:15 AM
dragonkj's Avatar
I looked at the cables and didn't see anything I tried to straighten and make sure they were as loose as possible.
Old Mar 18, 2013 | 04:22 AM
Have you re centered the steering wheel?
Old Mar 18, 2013 | 04:25 AM
dragonkj's Avatar
When I take it in for alignment would they align that too?
