ESP BAS Lights Stay On
Old May 22, 2008 | 09:41 AM
smokey's Avatar
Default ESP BAS Lights Stay On
I added cruise control last night and after I reconnected the battery the ESP BAS lights stay on. Do I need to get the computer flashed? I didn't see anything in the instructions that said I have to get the computer flashed after the install.
I am going on a trip this weekend and need to know if I have to get this fixed before I leave or can I drive with these lights on. I read in the manual and it said it needs to get fixed but it didn't say it would cause any damage.
Any help would be appreciated.
Thanks
Old May 22, 2008 | 09:46 AM
TSmith0820's Avatar
Is your steering wheel centered after the lift?
Ty
Old May 22, 2008 | 09:48 AM
ldwilbanks's Avatar
Default Damn Lights..
Have you driven at all since the install? Last night, I work on the clunky steering and when I put the steering shaft back in and started the motor, those damn lights were on. I was pissed. After racking my brain and checking all of the steering alignment and steering wheel, I decided to drive it around the block. When I started backing out of the garage, the lights went off and haven't come back on. The only issue was, I severed the driver's side airbag, because I didn't secure the steering wheel while tweaking the shaft. Drive a short drive.
Old May 22, 2008 | 11:10 AM
smokey's Avatar
I have had the lift on for a couple months with no issues. The issue didn't show up until after I installed the cruise control. I have driven it and I have disconnected the battery a couple times as well. As far as I know I put everything back on the way it was suppose to be after the cruise control install.
Old May 22, 2008 | 11:58 AM
Rubicon Rando's Avatar
mine stays on too... but that is because it was in 5' of water.... i dont mind i hated the traction control anyways
dealer wanted to much to fix it so i said feck it.
Old May 22, 2008 | 12:28 PM
all i did was turn off the esp then turned off the jeep. i let it sit for 5 minutes and turned it back on and no "bas" light
