ESP with new tires.
Old Mar 26, 2010 | 02:51 PM
Shop Teacher's Avatar
Default ESP with new tires.
About 1 month ago i lifted my 08 JK U X. I also added a superchips at that time. For a month everything was great. Two days ago I put black rock steel 16's with goodyear duratrac 285 75 16's. Two days and everything is fine... until. I was on an off ramp and my esp bas light came on and the jeep took over. Any advice?
Old Mar 26, 2010 | 02:56 PM
frankie945's Avatar
You can either turn it off. Or just live with it...
To turn off:
Shift transfer case into 4 High
Turn steering wheel until it is centered and wheel are pointed staight ahead
Cycle the Ing key off to on
Wait approximately. 5 sec for the system bulb check
turn and hold the steering wheel one half turn to the right clockwise
press and hold the ESP off button for 7 sec.
turn the steering wheel back to center,& turn & hold an additional one half turn to the left counter clockwise
press and hold the the ESP off button for 7 sec.
turn the wheel back to center
press and hold the ESP off for 7 sec.
Cycle the Ing key to off.
Repeat the same process to turn it back on.
Old Mar 26, 2010 | 03:25 PM
spinlock's Avatar
You must have been pushing your JK pretty hard on the off ramp.
Your mods alone should not have a significant impact. Is the tire pressure near the same on all tires?
Old Mar 26, 2010 | 05:58 PM
rubi08unlimited's Avatar
To turn off:
BTW, when you cycle the ignition key to on, go ahead and just start it. it works alot easier with the power steering. I fought with the damn steering wheel for about a half hour until I went to the dealer ship and their instructions said to start the vehicle. it worked the first time for me.
Old Mar 26, 2010 | 07:01 PM
wilywillie's Avatar
My first thought is that your steering isn't centered after front end work (lift, etc). Could this be a cause?
Old Mar 26, 2010 | 08:18 PM
frankie945's Avatar
Yes, it will contribute to premature ESP. The ESP reads off wheel speed and steering Wheel position.
Old Mar 26, 2010 | 09:40 PM
MasterG's Avatar
To turn off:
Never heard of this proc before.. It will turn off the ESP completely and permanently ?
Like when I hold down the ESP button when in 4HI ?
Old Mar 26, 2010 | 11:21 PM
zeppo's Avatar
It's the complete ESP disable procedure for the 08+ JK's.
Old Mar 27, 2010 | 12:33 AM
lang1864's Avatar
i wish they wouldnt have added electronic crap like that on these new jeeps.
Old Mar 27, 2010 | 04:08 AM
CJ7nvrstk's Avatar
Vet Army
At first I felt the same way though now I appreciate it. It helps when wheeling and you have one tire spinning or up in the air. Gets power to the other tire.
