ESP Problem After Lift-HELP!
I installed a terraflex 2.5 kit this weekend, springs and new shocks and frt adj track bar. When I start off II shut off esp because it keeps coming on. Then after about two minutes the ESP/BAS light comes on dash. Bad shaken if BAS light does not come on. I am not talking about ESP slippery road indicator. Is there anything I can do, to disable system or any other solutions.? Very scary shaken.
Try this link for the re-centering of your steering wheel. Even after re-centered it might take a bit of driving before it goes off.
http://project-jk.com/jeep-jk-write-...-end-alignment
To all those saying to "search the forum" thanks for nothing...hope you never have a question that was already asked
and for the ppl who say search why waste ours and your time with that message, go back to being a armchair quarterback and waste time on another thread
Make sure you use a torque wrench on your trackbar bolt, using a wrench wont hit the torque specs you need,
I'm about 40 minutes from Cortland, near 4wd hardware if you need help, Just send me a PM
