ESP Problems/Fixes
Old Jun 17, 2010 | 10:13 AM
LittlEvil's Avatar
Would like to give a huge shout out and thanks to Steve and the entire Full Traction crew for there knowledge and know how. Totally amazing group of guys. Quite possibly just saved me a ton of mulah and walked away knowing more than than what I started the conversation with. So again thanks
Old Jun 17, 2010 | 10:18 AM
Full-Traction Suspension's Avatar
Former Member
No problem, thanks or calling in and getting this taken care of
Old Jun 18, 2010 | 06:20 AM
nrs's Avatar
nrs
What did you end up doing to resolve the ESP issue?
Old Jun 18, 2010 | 06:42 AM
Former Member
He had to much PSI in his tires.
Old Jun 18, 2010 | 07:02 AM
artpics's Avatar
Front lower Flexarms installed no ESP problems for 7 months set the arms a tad over 23"
Old Jun 18, 2010 | 07:45 AM
Former Member
That's great, but it's not what is causing his ESP issues. Over inflated tires was the issue
Old Jun 18, 2010 | 12:57 PM
LittlEvil's Avatar
Ok, so my tire pressure was a little high. I deflated my tire and started with 25psi moving up 1 psi till I got to 29 taking quick drives in between. Drove it to a local shop that specializes in alignments and had them look to see if my steering wheel was straight. They made a minor adjustment and presto, no more ESP problems. So far all the turns that normally set it off haven't. Theres just one more on my way home from work that is notorious for setting it off and trying to toss me into the bushes. Cant wait to see if thats the end of my ESP issue.
So far from what I can tell and what worked for me is tire pressure (29psi) and making sure my steering wheel was straight. Thanks guys for your advice and thank you Full Traction for the wealth of knowledge you bestowed upon me.
Now its time to install the ESP kill switch
Old Jun 18, 2010 | 02:43 PM
Verdulken's Avatar
Not sure about the 09s but on my 08 Sahara I didn't need a killer switch, there is a way of turning it off completely which I did almost a year ago and it works great, no more ESP problems since ESP is OFF !!!
Old Jun 18, 2010 | 03:21 PM
LittlEvil's Avatar
I had that for a while untill the notification and the ding became really annoying. After this fix Im deff gonna go with the kill switch. Just makes it easier to turn ESP off when I need it to be.
Old Jun 22, 2010 | 04:22 PM
Verdulken's Avatar
Found a thread to do the SW mod, sounds very simple. Will try maybe this weekend
https://www.jk-forum.com/forums/show...deperate/page2
