EVO 14" coilovers on a 2 door JK?
Old Jan 27, 2009 | 10:04 PM
Amway Man's Avatar
Question EVO 14" coilovers on a 2 door JK?
I've been looking at the posts on here with JKs and the EVO coilovers and have noticed they are mostly on the Unlimited JKs. Is there a reason for this or are they just more popular? I mean, are there significant drawbacks to running the coilovers front and rear on a 2 door JK? I wouldn't want to run larger than 40" tires, probably not larger than 37s. I'm trying to get all my ducks in a row on what will/will not work on a 2 door vs 4 door before making a purchase.
Thanks!
Old Jan 28, 2009 | 12:13 AM
Ctimrun's Avatar
Evolution has done a 2 door but I havent seen any pictures of it. This system on a 2 door would kick ass! The best thing to do would be to call Mel at Off Road Evolution and let him tell you about it! If/when you go this route make sure to post some pictures!
Old Jan 28, 2009 | 01:17 AM
oZmonKey's Avatar
I'd like to gander at some pics of a two-door with the entire EVO setup myself.
Old Jan 28, 2009 | 02:43 AM
BigTexRedneck's Avatar
40s on a 2 door, can you say top heavy
Old Jan 28, 2009 | 04:29 AM
asjackman's Avatar
In a couple days I will be purchasing the FT " LA with front EVO coilovers. I don't have the funds for the rear yet. I have a 2dr Rubicon and only plan on going to 37's. I'll post pics once complete.
Old Jan 28, 2009 | 05:57 AM
White Widow's Avatar
can you say who cares. tjs are running 40in + tires all the time whf you so worried about?
Old Jan 28, 2009 | 06:08 AM
Screamin Lizard Customs's Avatar
Sponsoring Vendor
Going to do a 4dr that has a 6" FT LA and is going to EVO 14" Coilover , EVO Rear. Has 37's now and all the 2Drs with 37" look good and wheel good. Whats 3iches I geuss.
Gerry
Old Jan 28, 2009 | 07:31 AM
Amway Man's Avatar
Gerry
Technically it would be 1.5" taller is all. Every 1" you go up in tire size only nets you 1/2" under the axle.
I've seen a lot of TJs with 40s and even 44s! Since their axles are more narrow and, if I'm not mistaken, their wheelbase is minimally shorter - should be fine on a JK, right?
Just trying to work out a few bugs before purchasing a JK in the next few months.
Old Jan 28, 2009 | 07:33 AM
Worthless's Avatar
There are guys out there wheeling Izuzu Trooper's and K5's and you're calling a JK too top heavy.
A JK is wider and longer, its probably proportional to a TJ but could be built very stable.
A TJ on 42's with full widths and about and a couple inches of lift with a 112 wheel base is more stable than a factory one, I would know, I have one.
Does anyone offer a rear kit that stretches the WB or does everyones stuff a add on to a long arm kit?
Old Jan 28, 2009 | 07:55 AM
Littlejon's Avatar
Rock Krawler has a long arm stretch kit, but you need to comp cut the corners to make it work.
