Evo adj lower control arms help
Old Dec 22, 2012 | 04:47 PM
Huggerls1's Avatar
Default Evo adj lower control arms help
Ok so started my enforcer lift. Got everything ready to be buttoned up but there seems to be a clearance issue.
Here is what the evo directions say and look like
It says make sure the control arms bend towards the inside of the vehicle which they are. The only thing I noticed was the gold screw was opposite as the picture so maybe the control arm is on the wrong side?
I'm done for the day but any help would be appreciated.
Old Dec 22, 2012 | 06:07 PM
Huggerls1's Avatar
I wish everything came marked. I don't want to have to take everything off to swap out the control arms. The springs were super hard to get in as it is.
Old Dec 22, 2012 | 06:08 PM
JKZinger's Avatar
When I installed mine with my coilovers I faced the bolted clamp part downward. Haven't had any issues.
Old Dec 22, 2012 | 06:41 PM
JHP81's Avatar
u can't just flip it?
Old Dec 22, 2012 | 06:50 PM
Huggerls1's Avatar
Ill keep that in mind. Hopefully they are just backwards and I can get them in correctly tomorrow.
Old Dec 22, 2012 | 06:51 PM
Huggerls1's Avatar
I could but just going by the directions it says to keep it on top.
Old Dec 22, 2012 | 07:25 PM
MTG's Avatar
MTG
I can't tell if they are on the correct side from the picture.
However, you shouldn't have to have the bolts facing down. Here is mine:
Old Dec 22, 2012 | 07:35 PM
Huggerls1's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=400949"/>
Thanks for the picture. The more I keep looking at it the more I think I need to swap sides.
Old Dec 23, 2012 | 06:38 AM
Huggerls1's Avatar
Morning bump. We will see how the day goes.
Old Dec 24, 2012 | 11:15 AM
MTG's Avatar
MTG
How'd it go? Were you able to fix it?
