EVO Draglink Flip
Old May 24, 2012 | 10:20 AM
  #21
sneck's Avatar
Originally Posted by Jeff minney
Attachment 320952
Here's a pic of mine if it helps.
hmmm, that looks different from what i have. what sway bar links do you have
Old May 24, 2012 | 10:22 AM
  #22
Jeff minney's Avatar
There evos
Old May 24, 2012 | 10:29 AM
  #23
sneck's Avatar
There evos
how old is that setup? I'm assuming everything was installed by evo? and you have a rubicon?
Old May 24, 2012 | 10:36 AM
  #24
6 months old and no I did all the install and yes it is a rubicon.
Old May 24, 2012 | 10:44 AM
  #25
EVO MFG's Avatar
Sponsoring Manufacturer
The flip kit works perfect with the EVO links.
Old May 24, 2012 | 11:57 AM
  #26
burbingus's Avatar
Attachment 320952
What disconnects are you using?
Old May 24, 2012 | 12:17 PM
  #27
They are Evo links
Old May 24, 2012 | 01:31 PM
  #28
sneck's Avatar
so to update, talked with andrew, its really a compatibility issue. anyone who has a prorock knows that swaybar bracket is tight to begin with, and adding the 3/16s bracket onto it just means its not going to work with the jks, or really any quick disconnect similar to it. obviously links that are closer to OEM (aka the EVO links) will be able to work just fine, but without shaving down some of the brackets on the PR44, the quick disconnects wont work. i might try to get in there with a grinder, but in the mean time, if anyone does get a quick disco to work with the pr44 (in general, since its tight) and the evo bracket, let us know! and take pics!
Old Jun 30, 2012 | 11:00 PM
  #29
TRAUMAhead's Avatar
Originally Posted by isolated1523
I'm installing this Friday...since I already have the purejeep truss, I.have to cut the bracket already and welding it, I may see if I can cut on the link side and avoid this issue. I'll let you know.
Have any pictures of it installed?
