EVO NoLimits On Demand and ARB
Old Aug 14, 2017 | 05:23 PM
blowermax's Avatar
Default EVO NoLimits On Demand and ARB
I currently have an EVO No Limits sway bar disconnect. At the time I had Elockers. I currently have ARB single air compressor and both air lockers. EVO has a No Limits On Demand version which is air controlled. I want to change to that system but I don't have room on my ARB for an additional solenoid and now I have to run additional wiring ect...I have one simple solution in mind but not sure if its a good one. Install a "T" on my rear air line locker....1 line goes to locker and 2nd goes to EVO...My only issue is with speed....Can I have the rear locker engaged at speeds around 25-45mph in the dunes.... Basicaly when my rear locker is on the swaybars will be disconnected...Please give me your thoughts on this or maybe a simpler solution????
Old Aug 15, 2017 | 06:22 AM
Canvas's Avatar
Veteran: Navy
that will work because the solenoid opens and ports air where needed. Should be ok.
