EVO Plush Springs with Zone lift
Guys I bought my JKU with a lift already installed and it appears to be the Zone offroad 3" lift. After reading posts here I'm looking to switch to EVO' s 3" plush springs. Obviously at first glance this should work.
But would someone with a little more knowledge mind looking at the Zone kit to see if there would be any problem with this? It's a pretty basic lift kit. I just want to make sure that they weren't expecting a 1" sag right off the bat so they included less hardware than what would really be needed for the true 3" I will get with the EVO springs.
Also, do you think another alignment would be necessary? For example if the sag is less on the EVO springs?
•Coil springs designed to give a full 3" of lift while maintaining a factory style ride. Our coils are 2door/4door specific, so be sure to select the proper application.
•Rear extended sway bar links are included. These links come with urethane bushings to increase performance and reduce body roll. The factory rear links are then used in the front.
•A rear track bar relocation system is included to perfectly center the axle under your JK
•2" bump stop extensions are included to protect your vehicle while still increasing wheel travel
•Brake line relocation brackets are supplied to allow for the dramatic increase in wheel travel
•New Zone front and rear shocks are included that are valved specifically for your JK
